Do the RB25 stock ecus have a disliking for boost?
I have a RB25 with full turbo back exhaust, pod and front mount and without a boost controller it makes a constant 0.8bar.
On really cold nights, it misses quite a bit under full load. I have heard the stock ECUs like to retard themselves when theres extra boost being pumped in. DUring the days it seems to run OK under full load.
Any ideas? Would a SAFC/SITC combo or PFC help this?
CHeers.
https://www.sau.com.au/forums/topic/122658-r33-gts25t-stock-ecus/
well seein as i was told this just 3 days ago search!!! lol
i had the same prob, thought it was coils, but yes 33 stock ecu sucks...
had a safc2 installed and it has fixed my probs :P
pfc or safc would fix this prob i think, but theres alot more knowledgeable ppl on here that could go further in depth about it.... or a 2min search ;)
RB25 ecu's have a air flow cut not a boost cut. When you hit the cut then you will know it - the whole engine cuts out and it feels like you just slammed the brakes on.
Sounds to me by your "missing" is that the boost is putting out the spark. My advise to you would be to gap the spark plugs down to .7 or .8 and try again.
You will be suprised =)
This is a known issue with slighty modified skylines - even stock ones. Works wonders.
CHeers.
safc only gets rid of the problem if you are running lean. if you are running rich and use a safc to lean it out you may get boost cut earlier. only way to get rid of boost cut is to get a aftermarket ecu, such as pfc, or a fuel cut defender. the new fuel cut defender from turbosmart should set you back about $230, but you then need some sort of fuel computer to stop it leaning out.
mad082 you have got it the wrong way round. SAFC only works if running rich and you are getting air flow protection.
E.g
Before SAFC:
5 volts on the AFM triggers Air flow protection and is giving 9:1 air flow ratio (rich)
After SAFC:
With the SAFC you want to lean out the fuel mixture so you intercept the AFM signal and change the 5v reading to 4.8v. This will fool the ECU that there is less load there - hence less fuel will be delivered and it may not trigger air flow protection. I.e. youmay now get 12:1 AFR and no air flow protection
Also it has to do with how quickly the rise in Air flow occurs ...e.g how quickly you go from say 3v to 5v - this may trigger Air flow protection
P.s. all values made up. But AFM reads 0-5v
0v = no air flow
5.1v = A lot of airflow (enough to make 170rwkw+)
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
