Hey all, I just purchased a 97 stagea rs4,
Have a few questions to which I have searched for but need more specific answers.
Its getting complied today, I have to take it down to NIZMO PTY LTD to get it done. All the car has is an aftermarket catback exhaust.
Firstly, How good are the guys at NIZMO, and how long does it take? Also, how much in your experience does it cost through them?
What exactly do they do? Fluids/belts/ac?
I haven't been able to get onto them so I hope they wont mind me bringing it down.
Just need quick answers to these questions, any help would be awesome
Thanks
Gavin
https://www.sau.com.au/forums/topic/122791-new-stagea-few-questions/
Thanks
Gavin
It takes 1 day to do the work, but takes 1-2 weeks to get it inspected and the compliance plate delivered from DOTARS
If you have bought this car, who did the compliance approval arrangement with NIZMO?
They should have advised the costs before they issued the approval
When I rang them, about 4-5 months ago, they were quoting approx $4000 plus GST plus tyres
That why i went to IAMSHE, $2750 plus gst and tyres series 1, $3000 plus for series 2
Who/where did you buy the car?
Here or from Japan?
If you have a catback exhaust, they will or you need to remove that and fit a factory exhaust to get it complied
NIZMO have changed hands in the few months, not sure who or waht the new owner is like
If NIZMO issued the import approval, you have no other choice but to take it to them.
Welcome.
Did you get an Import Approval from Nizmo?
If you bought the car in Japan it is the Compliancer who actually does the importing.
Did you buy thru an Agent like J-Spec or Prestiege? Or just deal direct with Japan.
I see you have been a member since January. You should have been doing all this stuff by reading the threads!
If Nizmo have the Import Approval you will have to go to them. If not I dont know what the proceedure is, but I would certainly recommend you consult Phillip White at IAMSHE. Ph 0755717133. Fax 0755715195.
Edited by 66yostagea
Sorry for the long reply... I took the car in on monday and its going to be finished on this upcoming monday (finally).
Yeah its costing 3500 plus tyres which I think are 120 each, and then I get it. The new guy that owns NIZMO now is very nice and knows his stuff. They had at least 5-7 stageas in there and they also had a blue kitted one with an r34 gtr front which looked gorgeous.
Anyway, when I get it I might post some pictures up, no doubt I will be asking more questions.
Thanks
  • 8 years later...
hi guys, any recent updates or information regarding who is the superior complier, iamshe or nizmo? going to import myself a series 2 rs4s as my first car and just wondering who to go through for the most hassle free, reasonable price. Thanks in advance for a post 9 years later haha.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
