Guest INASNT
Gfriend has been looking at getting 1.
Saw a real sweet 1 today 95 with mivec engine, veilside full kit, 2.5 inch with 5 inch tip exhaust, glitter blue paint and imac condition. Took it for a drive and the mivec screams over 5000rpm. Its an triptronic auto and like all mitsu front wheel drive cars it like to clunch when changing gears at high rpm and when sometimes slowing down fast.
Whats the difference between GPX, SR or whatever other models they have.
Oh this 1 was $23,000 with 46,000 on the clock and a real sweet ride.
https://www.sau.com.au/forums/topic/12295-any1-know-much-about-ftos/
  • Replies 40
My sister was looking at getting one a couple of years ago. Very much a chicks car FWD with some boot. The auto is nice as the manual has a dodgey shift feel.. Maybe it's just me on that...
my sister did a fair bit of research. A Mitsu dealer in Perth said they could get parts and would do her servicing !
Apart from that the MIVECS are grunty and move in the high rev range.
Overall a good car.. But $23K is a bit rich isn't it ?
Guest INASNT
puckish
this thing was real clean with new paintjob and drove really well, i even convinced myself i would drive it if we took it out, i dont know y but it was fun to drive.
skyline33
she might finiance it though a dealer or sumthing, bot 100% sure.
she need to sell her s coupe first tho
