Just got my GTR from compliance last week so i thought i'd share a couple of pics i took the morning after getting home. I'm pretty impressed with car. Is much quicker than i expected a stock GTR to be and I was suprised how different the gearing is from my old GTS-t.
EDIT: Here's a Few More pics i too ka few weeks ago
Edited by ookami
https://www.sau.com.au/forums/topic/123090-couple-pics-of-my-new-series-3-r33/
  • Replies 60
Look cool!! you will have to come down from rocky for the next gtr cruise!
Nice, very nice.
It shits me how people can think that 32 GTRs look better than the 33 GTRs.
It probably shits them that you think a R33 looks better
Im like Tom...all GTRs are hot! Nice looking example
ive always liked the 32 shape, but bcoz of the age, id go the 33,34, and even a V35 if i could afford one of the above. nice car though. i swear i saw your plates down here on the sunny coast like 2 years ago. was your old car white or yellow, cant remember??
nice car mate looks very clean.
if you dont mind me asking how much did it cost you get a a series 3 in that condition over and complied.
sorry to be nosey its just i have a r34gtt at the moment and i was thinking of selling and getting a series 3 gtr, but i dont really want to buy one here i will probably import myself.
also did you import yours yourself? would you do it for me for a fee ofcourse?or who did you go through to import?
any help would be muchly appreciated.
I'd also like to know as i'm in the same boat as wanting to knows the costs and hassles, also who you imported it through would be great if ya dont mind aswell.
Btw, sweeet ride! Go the GT-R's!
I went through an import broker for mine. Was a bit of hassle, but nothing too serious, just mainly time consuming. My compliancer helped me out heaps though, so that made things much less stressful :D - was still stressful at times though. As for costs I'd allow around mid to high 40s for a car on th road and ignore the estimated prices, their usually way off.. Vspecs were slightly more again :dry:.
Yeah for the money i think the R33 GTR Series 2 or 3 are the better buys in the GTR family these days...
However the V35 is getting quite tempting to me... Specially cause HKS make a twin turbo kit for it.... Yum...
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
