hmm you got yours already??
Wonder when i get mine. So cant wait!!
Whos puttin it in for your emsta?? n for how much?
btw can you install these yourself? Any problems??
i've heard of a few guys with very little mechanical knowledge installing these themselves, it will be pretty easy, just a bit of a pain in the ass. Have to watch for broken bolts etc, and if they do break they'll need to be drilled out. Soak em in WD40 or something similar for a while beforehand to try and free them up.
  • Replies 108
Yeah, I went and picked it up from Michael after work. I will be getting RE Customs to fit it in along with the cat back I ordered from them. Spoke to michael, he said it shouldnt be too hard to fit the pipes on, as they are specifically made for the R32/33/34. I wanted to do it myself - but I think since Im doing the whole lot I will just get a professional fit. Plus I need to get my car serviced and the new turbo timer to be installed anyway.
So after all that, it should be running a turbo back exhaust: BATMBL s/steel split dump/front + catco 3 inch large cat + Trust Power Extreme 2 cat back :(
Edit - im expecting atleast a 20rwkw increase with the whole system. Michael estimates it to be more than that - but we will see. All I know is that the increase in this system, will be more than what I was told with the x-force (which would have been 10 - 15rwkw max)
EDIT Again - REcustoms said they will do it for 900 - that price includes the price for the cat back. I will have to show them the split dump/front and cat first though - incase they might require a bit more for the install.
Edited by emsta2003
shif_tea- sweet might give it a go then.
Emsta- ahh let us know how it goes when its all in. 900 sounds alright i guess.
Edited by siddr20
hi guys
The first few pipes should be getting sent out toward the end of this week as they are being made as we speak (i dont have any stock atm, last pipe went to emsta). I have updated the list of the people whose payment has cleared in the second post of this thread. I will PM you each as your pipe gets sent out. All pipes should get sent out by end of next week, or hopefully earlier.
cheers
hi Guys
First 5 pipes went out today to the following people:
Zahos
Kozeyekan
shif_tea
blackbart
JaseR33
Next 5 or so will be Fri or Mon at the latest.
cheers
ill most likely be up for one. will they fit a non stock turbo? and what size are they? (please be 3 inch.. please be 3 inch)
cheers! james.
Mine came today and looks the goods.
So fresh, I can smell the sweet scent of mig welding.
Also, many thanks to batmbl on the packaging. Wrapped in bubble wrap, and coccooned in packing tape, that thing wasn't getting scratched or banged by even the most incompetant of delivery people.
Big thanks.
Highly recommended.
-Josh
You will get significant power increase in the top range. Thats what i have heard from friends who have got spilt systems installed.. Also helps your engine breathe which is a bonus, so more air pushing out faster= more power..
I heard up to 15-25kw increase..
HMM i wonder when i get mine??
Hope you sent some out today.. Really want it this week lol..
cheers
hi Guys
Zahos
Kozeyekan
shif_tea
blackbart
JaseR33
cheers
Hi Michael,
Did ya manage to send em yesterday? sorry mate dont mean to seem pushy just trying to arrange for everything to be fitted .
Cheers
Lee
What sort of gains am I to expect if I get these installed? Is this a significant power up mod or just to put some icing on the exhaust cake
According to Michael there should be a significant increase - and hes right. There is a huge difference IMO. id estimate and say atleast 20rwkws - but i still need to dyno it once i get a couple of more mods on.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
