17" x 8" ENKEI RP-01 BLACK
5 stud 114.3
offset is 38
2x60% rubber 255's
2x80% rubber 255's
Made in Japan
black with blue lining
Awsome wheels!!!
Were on R32 GTR
Super light weight!
perfect condition!
all four are 8'' wide
****sms for pics 0420560838****
$1000 firm for the set
WHEELS ARE 5 STUD, PIC IS JUST SO YOU KNOW WHAT THEY LOOK LIKE
  • 10 months later...
ARE THEY 4 stud?
or is that just a wrong pic?
do u have pics wif rubber?
they are 5stud, pic is just so you know what they look like...
sms me and I'll mms you a pic of them.
I only have a pic of them on my phone...
ive dealt with danny many times now,very honest guy, he has the wheels if thats what your wondering lol, nice lightweight rims for gtr, real enkie's...
cheers ryan... :laugh:
They look like 4 stud? is that correct?
With a 38 offset they'd be perfect for a GTS-t. In fact I'm surprised they were on a GTR. Offset for them is usually around 20.
Actually I love these wheels myself but bucks are a bit tight right now.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
