I use the Castrol Synthetic R 5w-30, will be switching to the Castrol EDGE 5w-30. Its the best oil i can get off the shelf in Broome, and i got my last bottle of synthetic R for $65. I recommend the Synthetic R, and the EDGE is supposed to be better.
Its a daily driver, just cruising no thrashing, done about 130,000 kms. Engine is in fine running order, going to be interesting when i open it up for a rebuild in another 15,000kms.
cheers
Evil
I've ran castrol 5w30 in the past, I found the motor used a little of it over the 5k period.
The usual motul 8100 5w40 it doesn't use a drop. I've also ran castrol 10w60 (oil pressure was simply too high) and Mobil 1 5w50 they too didn't use a drop.
I've found that Mobil and Castrol tend to go "used" prematurely - you start burning oil after 3000km because it's worn out.
Motul 8100 is brilliant stuff and always lasted me 5000km without using oil. Also, 10w60 is too thick for street use IMO.
It all depends on your driving and how many kays the cars done.
We stress too much about oil...
Grab what ever good oil you want it won't make or brake it.
I've never had issues with either mobil 1 or castrol not lasting 5000km's, I have however had issues with oil being used when its a 5W30 oil, 5w40 is fine and the lowest I would go.
personally i think the 10W60 is too thick. far better to choose a good synthetic ester 10W40. and yes i have used the castrol 10W60. personally i think motul chrono 300V 10W40 is excellent stuff, but I will know more after the next analysis.
Beer Baron,
Have you done an analysis on the castrol 10w60? I'm keen to see whats in it, being if castrol skimp on moly and what not. ;)
I did one on it (castrol formula R 10W60) about 3 years ago, but i'm not the sharpest tool with oils and ingredients etc. Just wanted to see how the engine was really. from memory my mechanic that read the results said it was ok, but nothing out of the ordinary. and i still think it's too thick. there is no need for a 60. maybe if you do track work and a too tight for an oil cooler running the really thick stuff may be a bandaid, but providing you keep oil temps in check with an oil cooler i think 10W40 is fine.
I'll post up the results on the chrono 300V. my instinct tells me the results will be good :laugh:
Castrol doesn't use Moly from what I've seen. No big deal though, Moly is overrated. 300V has the highest moly concentration I've seen.
Kinks, how do you know the oil is 'worn out'? Just by looking at the color, it doesn't tell you anything.
Natrually Cubes you wouldnt have used a drop of the Castrl 10W60 or the M1 5W50 because they are thick as :kiss:
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
    • Wrong side of sydney for me coming from Goulburn, but you should head along, all ages of Skylines will be very welcome
    • Yeah so physically that port is consult not OBD2, but also be aware that "JODB" is not really a thing - it came in around 2000(ish) but is not a standard like ODB is, each manufacturer had differences. If you are looking at ECU only and have a standard ECU, go with Datascan as Turbo Tapin said. Per another recent discussion here thought that won't do other systems like in a modern car, for example bleeding ABS
    • They're not rebuilt Racepace items. They were mint. From memory the were ex display stock that I bought off yahoo and he ran....from memory he barely used the REs when he replaced them with a set of Tein RS If have been stored correctly and not leaked fluid then they will be mint   As an observation the Racebuilt rebuilt Tein RA/RE/RS were a better street/club/track package. Really nice on the street and did good numbers at the track.  I think the factory Teins wont match the Racepace valving on the street but would be in the same window of performance on the track... albeit firmer
    • The one time that Clippy is actually useful!
