Slightly off topic - but I converted my HKS solid centre twin plate to a sprung centre and what a difference!
Apart from the typical twin plate rattle when the clutch is depressed, you would think it's a stock clutch (almost).
and the cost of the conversion?
have a twin HKS at home, waiting to go in, solid centred.. but i can see it will need to be rebuild within a year :D
i found my booster and master were both leakin so thats my problem, and the fact i got a slave with a bore of only 15mm and the stock gtr one is 19.05mm and nismo is 20.54mm so the change back to a gtr one will have a considerable difference compared to the pissy one i currently have and also when i fix the vacuum booster setup it should be like a new car to drive :D
yep u definately would have a longer fork by the looks of it.
longer fork means u need more travel so i doubt u could use a longer fork and a nismo slave together as the nismo wouldnt have enough travel to disengage it i'd imagine.
also my clutch is awesome now with the new gtr slave cylinder (3/4) and the vacuum booster is now fixed as someone had previously put the wrong size o-ring on to seal it and it was leaking.
i also adjusted the pushrod inside the vacuum booster abit longer to gain more travel on the slave :)
feels beautiful to drive now and it even rattles alot less which is a benefit :D
thanks for all the info peoplz
Brad
Edited by CruiseLiner
  • 4 months later...
aha, happy i found this thread. so just to confirm:
1. there should be a difference in clutch feel when the car is off/on - harder off, easier on?
2. a larger slave (like the nismo slave) will make the clutch softer?
cheers fellas.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
