I have a R33 skyline with a RB25DET stock turbo.
Now what I've gathered from reading forums is that it has a Garret produced T25 turbo with ceramic internals wich don't like very high boost.
A buddy of mine is replacing his T28 steel internal turbo on his 200sx s14 engine and I was wondering if it is a good upgrade on my engine, but most of all if it is bolton?
Now I've read trough lots of forums but some claim that the T25 on my skyline has a T3 flange to fit on the exaust header?
Will A T28 from a 200sx be a direct bolton on mye RB25DET header and is it a good cheap ugrade as the T28 should be slightly bigger then the T25 I have? also it has steel internals and should be safe to run 1.2bar boost on it.
https://www.sau.com.au/forums/topic/123721-s14-turbo-on-rb25det/
No it is not a bolt-on upgrade
And no its not a good cheap turbo upgrade :P
Why not?
The T28 is bigger then the T25, but not much. so it should produse more air mass and handle more exaust better.
The T28 has steel internals and should handle 1.2-1.3bar safely where as the T25 rarely handles over 1.0 bar over time without the ceramics to crack.
And do you know there is a flange difference or do you only think so?
Why not?
You ask for the answer, i give so you can receive the information, and then you question it :P
The Stock RB25 turbo does not handle 14psi at all, not that they make much power over 12psi anyway as its just huffing hot air around.
I think you have some mis-information
The flange is not the same, one is T3 the other is T28... otherwise i would not have said
I thought skyline turbos were bigger than T25's??? what exactly are they T3?
Well I thought that the RB25DET had at T25 wich is smaller then the T28 on the SR20DET engines.
And bigger is better, so why would not the T28 be a upgrade? I want the "why's" and "why not's":D
Or does the RB25DET have a T3/T25 hybrid of some sort?
Now Im confused because I've always thought that the engine had a small standard T25
The rb25 turbo is not a t25 turbo, it is bigger and would make alot more power if the wheels weren't ceramic.
The T28 has steel WHEELS and should handle 1.2-1.3bar safely where as the T25 rarely handles over 1.0 bar over time without the ceramics to crack.
the rb turbos have ceramic wheels.
the flanges are different, T3 instead of T28 as mentioned before
nothing will bolt up, questionable power increase. definitely not worth the money of gettin manifold modded, lines, dump pipe etc.
and your goin from ball bearing to non ball bearing.
T3 is not a turbo, it is a flange
Just so you have a bit more of an idea on why there could be confusion - both the SR20DET T28 turbo and the stock RB25DET turbo run the SAME turbine wheel, which is also the same as the one on the POS T25 turbo which came on CA18DETs and S13 SR20s. This could be why some people say the Skylines have a T25 turbine. So do Silvias :ermm:
T28s from Silvias (as stated before) are T2x flanged while the Skyline units are T3 flanged (despite having a T25 turbine wheel) - and all the inlet and dump pipe plumbing fit to the two turbos differently as well, so doing the swap would be quite a fabrication-intensive task. The housings on the RB25 turbos are larger - and I'm pretty sure (not 100% though) that the compressor wheel on the RB25 turbo is also larger than the T28 unit.
In terms of making more power because "SR20 T28s aren't ceramic and can handle more boost" - the ability to hold together at higher boost is irrelevant. A T28 from an SR20 would be maxed out at the level an RB25DET unit can reliably run up to anyway - so while the turbo can run over 1bar on an SR20, it'd be useless on an RB25 because all it will be doing is blowing hot air and getting sad - and more than likely dropping boost.
It is definately not a worthwhile upgrade.
Just so you have a bit more of an idea on why there could be confusion - both the SR20DET T28 turbo and the stock RB25DET turbo run the SAME turbine wheel, which is also the same as the one on the POS T25 turbo which came on CA18DETs and S13 SR20s. This could be why some people say the Skylines have a T25 turbine. So do Silvias :D
Thank you for a very informative answer :dry: seem to have cleared all this up with that.
I'll tell my buddy with the T28 to throw it at someone else =)
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
