Paint finally done.
Looks good
What size spacers are you running on the front to fill the R34 guards out? 20 or 25mm?
Also looks like you have flared the rear guards as well?
My car would have looked very similar if I decided to stay with the factory silver
Can you provide a close up pic the the bonnet hinge mounts. I need to re fab mine.
cheers mike.
I think I joined your club 'fear of speed humps and spoon drains'.
and driveways. :)
my driveway is like a speedhump and i have to be +50º from straight to get out without scraping.
at least its a 2way driveway. so i have room to swing. otherwise i'd be fkd.
Thanks for all the comments.
30mm spacer on the front and the rears were flared when I bought it but I had them reshaped a bit because they looked pretty bad.
Color looks a little darker in the flesh. It's R35 gunmetal with a little silver added to it. Close enough I didn't need to do the door sills and still look ok.
Wheels are just resprayed the original Nur spec color.
Here's the only good pic I have of the hinges. You can also see the difference in color.
My latest purchase, crappy camera phone picture.
Would this have been on a car transporter a couple of weeks ago sporting NSW rego?
I spotted an S2 DAYZ on a truck heading south on Heaslip road a few weeks ago.
Neat ride.
*EDIT*
Just noticed that it still has NSW rego in the photo
Took the bus to Prescott Hill and spent sunday going up it http://www.prescott-hillclimb.com/
The stagea at Prescott Hill on sunday
Running consistent 59s/1min runs all day which i was very pleased with considering the lack of power compared to most things running up the hill and the extra weight. Need to take more brave pills for the final corner (30ft straight drop to the left) and esses
Been a bit of a lurker for a few weeks, so thought it was about time to put up a pic or two of the newly aquired wagz:
2002 M35 250 RS-V (yes, the VQ25DD with 4 speed auto). Had to buy it as imo its the only decent looking M35 i had seen to that point and the Impul kit really sets it off.
Loving it so far, just need to sort out some nice rims and i'll be done with it  :D
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
