hi guys ive recently bought a r33 gts t
im new to these cars and the a lsd light comes on sumtimes for no reason as far as i know can any one help me with this is this a common problem and also are there certain hydraulic pumps and computers to check for the lsd or anything like this any info would be great cheers
https://www.sau.com.au/forums/topic/123814-a-lsd/
Yes skylines can have an A-lsd light.
It means you have an active spec LSD version of the skyline.
Run some searches there's a shipload of info on this site about the A-Lsd.
As for it intermitently turning on. Do you have a power-fc? If you do I strongly suggest you look at the signature of a guy on here called PaulR33 as this is a fault that happens with the A-lsd failing and power fc's, but he's got the cure (read: DIY) to fix the problem.
If you don't have an Power FC.
Perhaps a fault with your abs sensors or the computer itself, or the hydralics, or a lack of fluid?
https://www.sau.com.au/forums/topic/123814-a-lsd/#findComment-2286171
Some Gtst's came with the vspec diff you are very lucky as they are a rare option.
The A-LSD light in the tacho it only comes on if there is a problem. The ECU for the ALSD is in the boot. Does it stay on always or just come on now and then?
Chris
https://www.sau.com.au/forums/topic/123814-a-lsd/#findComment-2286173
Nah, Actually, this site is pretty gay regarding a-lsd. I keep asking about certain things about a-lsd.
No one knows what fluid it uses. no one knows how to bleed the system.
No one actually knows how it performs relative to the normal gtr 2way diff.
Searching will get you info about fully sik people talking about fully sik stuff. but nothing actually useful about the a-lsd.
Like there's info about how people have installed fully sik power fcs into their fully sik skylines to make them fully sik and go quicker.
does someone actually know anything useful about the a-lsd? if so, please post.
https://www.sau.com.au/forums/topic/123814-a-lsd/#findComment-2286188
Check fluid in a space in the boot on the right hand side, you'll see a little canister behind a little clipped on segment.
The fluid it takes is power steering fluid.
As for the microtech, this might be causing the problem, from memory the A-Lsd computer requires a signal from the ECU that aftermarket computers generally don't give and have to be modified to suit.
Here I've run the search for you, check this link out:
http://www.skylinesaustralia.com/forums/in...howtopic=107656
Now I realise that you don't have a power Fc, but the premise behind the solution should be the same for the microtech.
https://www.sau.com.au/forums/topic/123814-a-lsd/#findComment-2297867
hmmmm. i love it when people get credit for my work :
putting it simply.. while driving the light will come on when the wheels slip. (lets you know its working)
if not. you need to aply the tps signal to the a-lsd ecu. just check "moonie" 's topic on a-lsd. i fixed it for her at wsid :dry: with a multimetre and some eletrical tape :)
https://www.sau.com.au/forums/topic/123814-a-lsd/#findComment-2300251
if not. you need to aply the tps signal to the a-lsd ecu. just check "moonie" 's topic on a-lsd. i fixed it for her at wsid :) with a multimetre and some eletrical tape :whistling:
Hey man, apologies, credit where credit's due.
I just remembered following the post about the fault with the A-Lsd (As I have one in my car, but my ecu is still standard), and remember Paul copying it to his link on FAQ on A-Lsd's.
https://www.sau.com.au/forums/topic/123814-a-lsd/#findComment-2300910
how about if someone actually says how to blled the syhstem and what fluid it uses?
There is a bleeder nipple on the right hand side under the car runs along the right hand chassis and is roughly above the diff cradle. Make sure the car is running and bleed out the air from there.
It is difinitley power steer fluid. It will also read low when the car is off! So don't over fill it.
https://www.sau.com.au/forums/topic/123814-a-lsd/#findComment-2301216
cheers for all the info guys i mite attempt to bleed it on the week end there is red oil ontop of another coloured oil like some one said on a previous post in my canister so i mite replace it can anyone tell me a specific type of oil to use and a rough price
cheers guys
https://www.sau.com.au/forums/topic/123814-a-lsd/#findComment-2308992
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
