  • Replies 73
just do the last few subjects part time if you get the job. work experience is more important than uni experience (yes i went to uni full time, wish i didn't)
only 6 months to go! may as well get the degree over and done with! (comp sci, monash clayton)
i've been working casual as a network admin for a couple of small offices, very similar to the sort of stuff they mentioned in the add, so sadly they aren't advertising at the end of this year, otherwise i'd be applying!
I would give them until Friday and perhaps make a call in the afternoon unless they gave you any details during the interview about quantities of interviewees, time spans to interview them etc. I would always add a week onto the end.
Good luck anyway and hopefully roll on the group buy :D
ive always thought if a company is hiring someone to do a range of tasks instead of a few ppl that specialize in various things there usualy kinda cheap...
im betting around the $50k mark :)
With 3 to 4 yrs experience & the wide range skills they are asking for, I would expect $70-$80k+ IMO.
Emailed them for a $ figure anway.
Thats easily gonna top 50k.
Im with Dave. well into the 70k region. If not more
I mean, the stuff this role incorporates, my work pays people closer to 80k no problem.
Im on the chicken feed @ around 50k and i dont do anywhere near that sorta stuff :)
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
