  • Replies 73
just do the last few subjects part time if you get the job. work experience is more important than uni experience (yes i went to uni full time, wish i didn't)
only 6 months to go! may as well get the degree over and done with! (comp sci, monash clayton)
i've been working casual as a network admin for a couple of small offices, very similar to the sort of stuff they mentioned in the add, so sadly they aren't advertising at the end of this year, otherwise i'd be applying!
I would give them until Friday and perhaps make a call in the afternoon unless they gave you any details during the interview about quantities of interviewees, time spans to interview them etc. I would always add a week onto the end.
Good luck anyway and hopefully roll on the group buy :D
ive always thought if a company is hiring someone to do a range of tasks instead of a few ppl that specialize in various things there usualy kinda cheap...
im betting around the $50k mark :)
With 3 to 4 yrs experience & the wide range skills they are asking for, I would expect $70-$80k+ IMO.
Emailed them for a $ figure anway.
Thats easily gonna top 50k.
Im with Dave. well into the 70k region. If not more
I mean, the stuff this role incorporates, my work pays people closer to 80k no problem.
Im on the chicken feed @ around 50k and i dont do anywhere near that sorta stuff :)
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
