  • Replies 73
has anyone applied for this one yet? I know Patrick and I applied for the Soft Eng position, but haven't seen anyone saying that they're applying for this one.
They also have a dyno in the building :)
I'm fixing up resume now.
Might give it a go. But i'm not moving for less than 70k.
Congrats to Patrick if he did get it :rofl: D'oh for me though lol, I thought my experience would let me down, another 6-12 months I should have the required C++ experience, but doesn't help right now :) I guess I should be expecting a commiseration call :woot:
Yeah, after three interviews I got a letter of offer today, starting there on the 31st of this month.
The gtr is in for some tough times now i think :nyaanyaa:
Best of luck with other jobs Justin, apparently they had between 50 and 100 applicants for this position. Honestly i'm surprised i got the offer.
-Patrick
Congrats :rofl:
I'll probably stay where I am for now and try to get my C++ experience up over the next 6-12 months. Of course I'd hope to get an inside word on any other positions opening there :O
They said in the interview that most people got the number wrong during the test, so I can at least take heart that I got it right :nyaanyaa:
Yeah that thing was easy, felt like I was back at uni again.. they did a few nasty things though, for example
Class c
public:
c(int x, int y) : mx(x), my(x) {}
private:
int mx;
int my;
(both 'mx' and 'my' are initialised with the constructor parameter 'x', 'y' is unused)
Once they got onto asking me about design patterns things got a bit more interesting >_<
yeah there were a few traps for the unwary, usually with not using y when you expect them to etc.
My design patterns knowledge sucks :( Uni never covered them, and I haven't had to use any, I could name a singleton though >_<
More study required! I think I may have to do some more personal projects to help, does the world need more Consult software? :(
There was an awesome job for Bosch advertised last year where you design new ABS, stability control and traction control systems and get to travel to places like iceland, germany (nurberg ring) etc and actually test the systems out in different conditions. Needed alot of C++ knowledge also. Dream job
Haha, though the thread title says otherwise, the position Patrick got was the Software Engineer position.
I heard someone went for the Sys Admin position and didn't like the number
Here's a reply to my email qn to them re:$$$...
Hello
Re: your query on salary range for the Systems Administrator position we have available, we don’t put a set salary on our positions available; we have a range, dependant on skills & experience, and work around that basis with the successful applicant.
If you would like to let us know the salary you are seeking, we can advise if this falls into the range we are able to offer
Regards
Jeanette Ralston
MoTeC Research Centre
121 Merrindale Drive
Croydon Sth VIC
Ph: +61 3 9761 5050
Fx: +61 3 9761 5051
www.motec.com.au
mmm.. It's definitely beer time, last day of bloody sinus medication today, bring on the weekend!
As far as the $ is concerned, it's competitive with the rest of the market, this rate is for a 6 month trial contract. I think there's a possible re-negotiation at the end of that.
-Patrick
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
