  • Replies 73
has anyone applied for this one yet? I know Patrick and I applied for the Soft Eng position, but haven't seen anyone saying that they're applying for this one.
They also have a dyno in the building :)
I'm fixing up resume now.
Might give it a go. But i'm not moving for less than 70k.
Congrats to Patrick if he did get it :rofl: D'oh for me though lol, I thought my experience would let me down, another 6-12 months I should have the required C++ experience, but doesn't help right now :) I guess I should be expecting a commiseration call :woot:
Yeah, after three interviews I got a letter of offer today, starting there on the 31st of this month.
The gtr is in for some tough times now i think :nyaanyaa:
Best of luck with other jobs Justin, apparently they had between 50 and 100 applicants for this position. Honestly i'm surprised i got the offer.
-Patrick
Congrats :rofl:
I'll probably stay where I am for now and try to get my C++ experience up over the next 6-12 months. Of course I'd hope to get an inside word on any other positions opening there :O
They said in the interview that most people got the number wrong during the test, so I can at least take heart that I got it right :nyaanyaa:
Yeah that thing was easy, felt like I was back at uni again.. they did a few nasty things though, for example
Class c
public:
c(int x, int y) : mx(x), my(x) {}
private:
int mx;
int my;
(both 'mx' and 'my' are initialised with the constructor parameter 'x', 'y' is unused)
Once they got onto asking me about design patterns things got a bit more interesting >_<
yeah there were a few traps for the unwary, usually with not using y when you expect them to etc.
My design patterns knowledge sucks :( Uni never covered them, and I haven't had to use any, I could name a singleton though >_<
More study required! I think I may have to do some more personal projects to help, does the world need more Consult software? :(
There was an awesome job for Bosch advertised last year where you design new ABS, stability control and traction control systems and get to travel to places like iceland, germany (nurberg ring) etc and actually test the systems out in different conditions. Needed alot of C++ knowledge also. Dream job
Haha, though the thread title says otherwise, the position Patrick got was the Software Engineer position.
I heard someone went for the Sys Admin position and didn't like the number
Here's a reply to my email qn to them re:$$$...
Hello
Re: your query on salary range for the Systems Administrator position we have available, we don’t put a set salary on our positions available; we have a range, dependant on skills & experience, and work around that basis with the successful applicant.
If you would like to let us know the salary you are seeking, we can advise if this falls into the range we are able to offer
Regards
Jeanette Ralston
MoTeC Research Centre
121 Merrindale Drive
Croydon Sth VIC
Ph: +61 3 9761 5050
Fx: +61 3 9761 5051
www.motec.com.au
mmm.. It's definitely beer time, last day of bloody sinus medication today, bring on the weekend!
As far as the $ is concerned, it's competitive with the rest of the market, this rate is for a 6 month trial contract. I think there's a possible re-negotiation at the end of that.
-Patrick
    • Thanks for that mate always a good help
    • It's not really a calibration issue, if the voltage is really at 2V. If the voltage is 2V, then that's what the TPS is putting out, and the Haltech is seeing that and 2V is about 40% open (you know, between 0.45v being closed and something close to 4.5V being fully open). So, that would suggest that the TPS is maladjusted, on crooked, something something something. Or a wire problem.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
