  • Replies 58
Hi guys, we have found no difference in the flow of the R34 RB25DET injectors to the R33 RB25DET injectors, they both appear to be 370 cc's. We get around 250 rwkw (400 bhp) on the standard injectors in both before they run out of flow, that's using a GTR fuel pump though.
We use Series V RX7 Turbo injectors in RB20DET's as they are 550 cc's and top feed, high impedance so they work with the standard ECU (or Power FC) without any hassles.
I know that the R33 RB25DET's injectors are side feed, high impedance but I have not yet had to pull a set out of an R34 RB25DET, so can't help there.
INASNT,
given that they flow 370cc/min each at 100% duty cycle, i calculate that they should be good for a total maximum of approx. 440hp or 330kw (flywheel) which would give you your 250rwkw.
Although, of course, i'm not too sure if the OE fuel pump can keep up with the fuel flow needed for this power, but yes, a hi-rise fuel press. reg. would definitely help.
The fuel pump pumps less volume of fuel the more the pressure is raised. So to squeeze every last drop from the std injectors then you need a very big pump to be sure of decent fuel supply. A bosch 044 would be the go and then you can get quite alot out of the std injectors.
Hi INASNT. you asked "how did u manage to get 250rwkw out of the stock r33 injectors?"
We have done this more than 5 times in R33's and twice in R34's, so it is certainly not a one-off, lucky break. We generally use R33 GTR fuel pumps and Tomei fuel pressure regulators. The exceptions were that one of the R34's had a Tomei fuel pump and no adjustable fuel pressure regulator and one of the R33's had a Bosch 044.
All of them had Power FC's and were tuned for air fuel ratios between 11.5 and 12 to 1. They had a variety of other mods including hi flowed, HKS & Garrett upgrade turbos, camshaft pulleys, camshafts, exhaust manifolds, exhausts (generally with split pulse dump pipes) etc.
When we put an R33 standard fuel injector to the flow test (after ultrasonic bath cleaning) we find that they have flow rates ranging from 380 to 395 cc's. The 370 cc rating has always seemed to be a bit conservative. When we over pressure them (using a higher flow and pressure pump and adjustable fuel pressure regulator) we find an extra 10% flow is typical and sustainable ie; 420 cc's is very common.
The real world experience is backed up by the mathematics, if you take say 6,500 rpm, at 2,476 cc's, over 6 cylinders, with an a/f ratio of 12 to 1 and boost of 1.3 bar, you end up with 313 cc's of fuel being required every minute. If you allow 80% duty cycle ie; leaving 20% for acceleration, start and cold run enrichment, that = 391 cc's which is within the scope of a standard 370 cc injector to provide.
Hope that helps.
PS; that's why we never do the "GTR injector in GTST" mod, the extra capacity with 440 cc's is simply not worth the effort (or cost) when we can easily get 420 cc's out of the standard injectors.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
