Ok so I have killed my auto. My 3-4 clutch and possibly 2-4 band are dead. I have also been told they can be strengthened to take 230kw but beyond that the input put Shaft and Forward Planetary set are a weak point.
I am waiting for a quote to repair and strengthen it.
I am thinking that if the difference between a repaired and strengthened auto and a manual conversion is not too big I will look at doing the manual conversion.
I know most of the manual conversion stuff has been done to death in other threads but a few key things are still unanswered.
1. Why can’t a R33 GTS-t or R34 GTT clutch master cylinder be used?
2. Why can’t a R33 GTS-t or R34 GTT clutch pedal be used?
3. Why can’t a R33 GTS-t, R34 GTT or cut down Stagea brake pedal be used?
4. What about R33 GTS4 parts? Dose a GTS4 have a booster for the clutch?
It seems that if they can a fair bit could be saved. Has anyone actually tried using these parts?
So far the reasons have been that:
The GTR clutch master cylinder with booster is needed otherwise the clutch pedal will be too heavy. But plenty of people run the same clutches in R33 GTS-t as they do in R32 GTR’s and Series 2 Stagea manuals don’t have the booster. It seems like you would just need to pick the right clutch.
It has also been said that a Skyline clutch pedal wont bolt in and that a 260 part needs to be used. But what is the difference is it just a matter of drilling holes for the bolts in a different location? What about using a Stagea Series 2 pedal?
I’m not that worried about the interior at the moment, I can work that out later. I can do everything except for fitting the gearbox, fly wheel and clutch my self and would do that too if I had a hoist and gearbox jack.
I would fit the clutch pedal, MC and mod the brake pedal for clearance or fit a R33 GTS-t pedal my self before taking the auto out. Then take it to a workshop to take out the auto, fit the flywheel, clutch and gear box.
Gear box $1,200
Clutch / Flywheel $1,000
2nd hand R33 GTS-t Clutch peddle bits $500
R33 GTS-t hand brake cable and lever $50
Labour $800
Total $3,550
https://www.sau.com.au/forums/topic/123901-the-new-manual-conversion-thread/
Gear box $1,200
Labour $800
Total $3,550
Too many questions, but I will have a go
1. Series 2 stagea master cylinder is the same as R34 GTT $115 new
2. Series 2 stagea clutch pedal is different. not sure why, but only $87 new plus $115 for the mounting bracket. No need to muck around, just fit it
3. Refer to number 2
4. The only reason I can think a GTR uses a booster on the master cylinder is so you can fit a heavier clutch to suit the power level a RB26 can/could produce
I have ordered a Nismo slave cylinder as it bigger then the standard one, which will help with any heavier clutches $140 new
If you use a 32 GTR standard push type gearbox the clutch kits are nearly half the price of the R33 GTR pull type
R32 GTR gearbox $500-900
R33 GTR gearbox $850-1100, has been a few for sale lately for $1000 (lower k's than a r32)
Fly wheel $50 plus machining $50
Clutch kit R32 $500 R33 $900
Clutch pedal, bracket and master and slave all new $460
R33 brake pedal and bracket $50
Handbrake R33 $50
Braided clutch line $100
Centre console $750 thru R33Stagea
You can and will need to fit the handbrake at home when fitting the pedals etc.
I was looking at my car the other day, I need to change my brake booster when I upgrade the brakes to R34 ones and thought once it is out it will give me enough access to drill the holes thru the fire wall to mount the clutch master cylinder. The only problem is tring to get them to line up in the right spot to suit the clutch pedal mounting bracket, which has studs that protrude thru the fire wall from the the inside to bolt the master cylinder to.
Did Keas tell you that? Feel free to do a manual conversion and don't by any means let me stop you but that's BS and more proof that the only person in Australia who knows these boxes is Mike at MV Automatics in Adelaide.
Mike does an upgrade rebuild for about $3500 including modified valvebody for sharper shifts and rebuild torque converter for different characteristics. Obviously this would be cheaper if you don't want those two things but he does seem to recommend it.
Mike warrants that it can handle at least 300rwkw and that's only because no one has put more through one of them to test higher power levels. I have 255rwkw and I thrash it everywhere. NPs.
The only other thing I will say before I huff on out of here is surely a second hand auto wold be a cheap solution to your problem?
Sorry to intrude guys. Just putting in a point for the much maligned auto. Now you can go back to the point of this thread.
I might aswell put in my 2 cents then. My auto is shagged also.
R33 GTS25 4WD Gearbox
R33 GTS25 Flywheel
R32 GTR Clutch & Pressure Plate (New)
R34 GT-T Clutch Pedal
R34 GT-T Brake Pedal
S14 Clutch Master Cylinder
R32 Clutch Line
R33 Handbrake Assembly
R34 Centre Console to blend with Stagea Console
I'll let you know how it all went on Monday
tRUkbOY
I’m very interested to hear how you go. Would be good to see some pics,
How much did all your parts cost you?
darrinspencer
So using R33 gear box that works out to $2,700 worth of parts excluding the interior bits Then if you include $1,000 labor $3700 and your on the road.
Have you done your conversion yet?
Not really that much more than performance rebuilt auto at $3,320 installed.
Abo Bob
I have spoken to Mike at MV and he definitely sounds like he knows what he’s doing and about the same cost as Keas for a more comprehensive rebuild.
How do your find your Trans for every day driving? Not too harsh on gear changes when just commuting.
darrinspencer
Burns
I paided
$850 R33 g/box
$450 to get s/hand clutch rebuilt
$650 for s/hand interior centre console
$460 for clutch pedal setup new
Plus the other bits
approx $2700 all up
Labour I will do myself
I will be doing the manual conversion and the GTR front conversion as soon as I get it it complianced in approx 4 weeks
Then I will get it registered
My apologies for not reposting about the conversion.
Started the swap at 1pm on Saturday & I drove it home at 7.30 Sunday night, as a manual. Took approx 18 hours, 2 packs of cigarettes & 22 Coronas. Had access to a hoist & gearbox lifter & 3 or 4 other people for manpower.
I have posted a 'How to' on SDU as SAU was down yesterday for some reason.
Here is the link http://www.skylinesdownunder.com/forums/showthread.php?t=51894
I could post a Complete thread here as well if people are interested.
Stagea goes FANTASTIC now by the way!!!!
All up it cost me NZ$1880 + beer & fluids.
I am still yet to finish the console & fix down the handbrake but I'll do that this weekend.
Great effort!
Would be good if you could add your detailed how to do post to the original manual thread
So the R34 clutch pedal and mounting bracket fitted then?
Also it was a relief to see the clutch master cylinder mounting hole locations were already there in the fire wall. Saved a bit of guess work
Was it easy or hard to get a drill and hole saw to that location from inside the car?
Great effort!
Will do that
Yup yup, bolted straight up. Can't say them same for the R34 brake pedal though
Actually wasn't to bad. Used a 40mm holesaw. Easy as
Good work. I found your post on SDU just after I posted here.
I have begun getting prices for parts now.
I could probably do it all my self if I had acces to a hoist and trans jack. It dosn't look like it will be too big a job for a workshop if I do everything else.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
