hey all just about to purchase some new ROH adrenalinz in the shadow chrome for around 340 a rim, just see'n if any1 knows of a better price or more importantly a good choice of tyre to replace my 255's on the rears that are looking more like slicks... any suggestions on types that are good? i have budget 235 P5000 on the front and 255's of the same on the back...
any advice would be helpf00l
:D
ch33rs mile$
https://www.sau.com.au/forums/topic/12448-good-price-on-rimstyres/
One word of advice, rims and tyres, DONT go to the big shops like bob jane, etc, they will rip you a new hole, and stretch it for you too.
Go to a small, local tyre guy, they dont always have everything in stock, but can get it in, and will do good deals just to get your business, cause they need it more than a big chain does.
Do your looking at a big place, buying at a small place. Saved me $700 doing it this way (wheels+tyres).
See roy or ray at Kostera's in kalamunda, r34 put me onto him and he's fantastic. Go for dunlops, fm901's or if you can squeeze it a bit more SP9000 or the Super Sport series. I got the sp9000's on the rear and they made a huge difference to the overall stability of the car around corners etc. grip well too for the drags.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
