I did something stupid... Very stupid.
It was a little dark and hooked up the new battery reversed.
It touched sparked and I instantly pulled it off.
She blew the main 75amp fuse and a 10am fuse in the car, the 10amp fuse has something to do with the dash lights as they dissapeared but now are back after replacing the fuses.
There's no pfc display and no fuel pump prime also.
Car spins over but she doesn't fire.
I've noticed there's no more relay click down near where the ecu resides, I have a bad feeling its the ecu.
Damn friggin stupid me.
Hey mate.
OUCH lol.
have you checked all the fuses near the steering wheel. possibly there may still be a fuse blown there thats why your fuel pump prime may not be hapening and no display on your power fc. double check all of them. if not doesnt sound good. but all your fuses are there to protect that sort of short. if not maybe your ecu. but yeh double check all your fuses and let me know how you go.
cheers dan
Will double check.
I did rip them all out one by one but have plenty of time on my hands so I will do it again.
I've opened up the ecu and nothing appears burnt, I've looked real closely at everything and it all appears aok. Doesn't mean it is though. :)
Why don't car manufacturers slap in a big arsed diode to protect the stupid. argg. :dry:
yeh i know.....
and yeh doesnt mean the ecu isnt fried, but a power surge like that should fry something enough to make it visble. but i have blown a fuse once before and power fc wouldnt turn on, no fuel pump, thats why i said that to start with. but yeh double check it and let us know,
goodluck dan
I've taken a heap of pictures of the pcb so if your interested I can email a whole heap or how ever.
After a little looking I came across whats circled in red.. I'm quietly confident this would have saved the PFC.
As you will know if you read the previous thread the RB20DET PFC is nothing more than an RB25 PFC thats had a couple of ecu pinsouts relocated.. Which is a well known wiring mod if you drop an rb25 in to an R32. :)
I spotted this while going through a heap of photo's I took.
Hrmm.. by eye it looks as if a machine did the cut, using the camera it looks like its blown. ?
What does this look like to you?
Even if it is the throttle switch power supply (pin 57) I don't understand how that will simply stop the pfc powering up, but yes.. Most likely another fuse I missed.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
