Thermostatic Cooler Kits, Single/dual Filter Relocation Kits
not sure if this has been asked yet, but does the single filter relocation kit have the 2 plug holes for oil psi and oil temp sensors? if yes, sign me up plz.
  • Replies 125
Posted Images
167+ or 157 retail,
trade is still more then 125 each
by my reckoning if retail is $167 trade should be around $100. previous earls accounts were 40% off retail. maybe give them a call they may sort you out for volume purchase. either way it definately should be less than $125 and I would say they keep stock.
Guys stock is still very low on most parts - these kits have been quite popular, so if ordering please be advised there will be a wait :dry:
100, plus 4 fittings still
its ok i have sorted some out from the states shouldnt be long till they are here :)
Hi,
For just the filter kit, it shouldnt be very long - i can check tommorrow and let you know, im pretty sure they're in stock, its the thermostats that are low/out of stock at the moment :ninja:
im after the termo and core but am wanting stainless braided lines. will the just jap relocator kit with braided line fit the termo and core???
As long as the connections are the same, yes, i dont have the justjap fitting sizes so i cant tell you for sure though
(sorry for the late reply)
How long are the hoses?
Is it a DIY to connect all the fittings on this hose?
Still no pics of an installation of this kit so have to ask...On the mounting brakets that come with it: Does the cooler end up with the pipes connected to the cooler sideways or on top when fitted in front of the radiator?
Edited by Edge
You can mount the cooler up or on its site, its best mounted upright so both hoses from to the top of the cooler
the kit comes ready to install,
u just cut the hose to the size you need them install it,
there is 4 thermostats left
this buy is becoming a very big problem, none of the local suppliers have any of the perma cool gear in stock till the end of the year and all my gear is sold out and my order from the states wont be here till late this year
so please find out if stock is in stock or when its coming before placing a order
nothign has gone to plan with this group buy ;)
  • 4 weeks later...
just wondering if the kit can be fitted without the thermostat for now until the thermostats become instock?
cheers
Jeremy
I want a cooler, single filter relocation kit and a thermostat.
Let me know when stock is available so I can pay for the gear.
No worries :laugh:
cheers
Jeremy
It can but it means a bit more hassle in the future :D
No worries :)
It can but it means a bit more hassle in the future :)
k no worries.
i have to wait till the end of november to get my tomei pump so i cant put my motor in till i get that now. any ETA on this cooler gear?
cheers
Jeremy
Steve, hook me up with a single filter kit, k&n filter and cooler for the GTR33 please mate. Not worried about the thermostat. Need to keep temps under control when the new turbs arrive.......:)
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
