me - Abo Bob - 235
Jon Bates - Primordial - 235
Steve Reddel - steve_gts4 - 235
Adam Parsons - nath95 - 220
George Rokkas - yogi000 - 235
Andrew Tuitahi - tuitahi - 100
John Charalambous - silver gts-t - 100 ??
Aaron Li - Godzl1975 - 100
Paul Lewis - Oz GTR02V - 235
Stan Choi - satanic - 100
Shawn Malkic - Smoky - 220
Iain Anderson - R33deviat - 250
Amanda Moore - BWA - 235
Ralph Louwdyk - Oz GTR02V - 100
John Penlington - boosted zed - 100
Steve Bowman - Oz GTR02V - 100
Shane - Oz GTR02V - 100
Ray Dean - 100
Daniel Mackie - Majanal - 100
Matthew Anthony - 100
That's a list of who is in and what they have paid. I need more payments guys.
Also, I need you all to fill out the entry form linked in the first post of this thread. I think only one or two people have actually done this so far.
  • Replies 640
Posted Images
Abo,
I cant get Shane to commit to the extra $135 until we get the GTS back up and running.
Looks like we spun a bottom end or snapped a crank bolt. ETA is 2 weeks so we are touch and go at this stage.
I will let Steve and Ralph know their $135 is needed and to fill in the form.
Thanks
does eastern creek have day licences or you need a yearly CAMS one? Mate is keen just figuring out total cost, if EC dont do day ones it will cost him SAU rego + CAMS + Track day.... ya?
CAMS have a day licence so min cost is:
SAU membership $60
CAMS day licence $40 (this amount can be applied if getting the full L2S later)
Event entry $235
Don't forget fire extinguisher.
I think we have 4 or 5 flaggies at this stage and need about 10.
SAU membership $60
Event entry $235
For the fire extinguisher, where would you be the best place to place a fire extinguisher. Also, can I fill out the form and pay the CAMS day licence on the day?
Two places are good. One, you make a aluminium strip that bolts onto the front two mounting bolts of the passenger seat. Second one you just use the passenger side rear seat mounting bolt. Remember you need to be able to reach it from the drivers seat.
You can pay the cams licence on the day but best to have your membership to SAU sorted well before then and form can be done on the day but they will not be happy about that so please try to get it to them well in advance.
Thanks
Will send tomorrow
It must have racing stripes :rofl:
Nah you can get the CAMS approved ones from Repco for about $30.. They actually say "CAMS approved" or something similar on the box (Quell/Chubb brand I think?). The requirements are that it's charged, has a metal bracket, is accessible from the drivers seat, and at least 1kg i think?
Consider getting a larger one if you can (1.5kg?). I had to use mine very briefly on the way back from the last wakefield day, and a 0.25 second squirt sent it well into the red (ie. needs to be recharged). It will be worth the extra $$ if you need to use it :)
Must be 900 grams minimum.
Must be easy to reach for driver.
Must be able to be released without tools - ie clips.
Must stay in place with up to 25 g's applied.
So basically the recommendation is for a metal bracket but it's not 100% necessary as long as the thing holds in there nice and strong.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
