me - Abo Bob - 235
Jon Bates - Primordial - 235
Steve Reddel - steve_gts4 - 235
Adam Parsons - nath95 - 220
George Rokkas - yogi000 - 235
Andrew Tuitahi - tuitahi - 100
John Charalambous - silver gts-t - 100 ??
Aaron Li - Godzl1975 - 100
Paul Lewis - Oz GTR02V - 235
Stan Choi - satanic - 100
Shawn Malkic - Smoky - 220
Iain Anderson - R33deviat - 250
Amanda Moore - BWA - 235
Ralph Louwdyk - Oz GTR02V - 100
John Penlington - boosted zed - 100
Steve Bowman - Oz GTR02V - 100
Shane - Oz GTR02V - 100
Ray Dean - 100
Daniel Mackie - Majanal - 100
Matthew Anthony - 100
That's a list of who is in and what they have paid. I need more payments guys.
Also, I need you all to fill out the entry form linked in the first post of this thread. I think only one or two people have actually done this so far.
  • Replies 640
Posted Images
Abo,
I cant get Shane to commit to the extra $135 until we get the GTS back up and running.
Looks like we spun a bottom end or snapped a crank bolt. ETA is 2 weeks so we are touch and go at this stage.
I will let Steve and Ralph know their $135 is needed and to fill in the form.
Thanks
does eastern creek have day licences or you need a yearly CAMS one? Mate is keen just figuring out total cost, if EC dont do day ones it will cost him SAU rego + CAMS + Track day.... ya?
CAMS have a day licence so min cost is:
SAU membership $60
CAMS day licence $40 (this amount can be applied if getting the full L2S later)
Event entry $235
Don't forget fire extinguisher.
I think we have 4 or 5 flaggies at this stage and need about 10.
SAU membership $60
Event entry $235
For the fire extinguisher, where would you be the best place to place a fire extinguisher. Also, can I fill out the form and pay the CAMS day licence on the day?
Two places are good. One, you make a aluminium strip that bolts onto the front two mounting bolts of the passenger seat. Second one you just use the passenger side rear seat mounting bolt. Remember you need to be able to reach it from the drivers seat.
You can pay the cams licence on the day but best to have your membership to SAU sorted well before then and form can be done on the day but they will not be happy about that so please try to get it to them well in advance.
Thanks
Will send tomorrow
It must have racing stripes :rofl:
Nah you can get the CAMS approved ones from Repco for about $30.. They actually say "CAMS approved" or something similar on the box (Quell/Chubb brand I think?). The requirements are that it's charged, has a metal bracket, is accessible from the drivers seat, and at least 1kg i think?
Consider getting a larger one if you can (1.5kg?). I had to use mine very briefly on the way back from the last wakefield day, and a 0.25 second squirt sent it well into the red (ie. needs to be recharged). It will be worth the extra $$ if you need to use it :)
Must be 900 grams minimum.
Must be easy to reach for driver.
Must be able to be released without tools - ie clips.
Must stay in place with up to 25 g's applied.
So basically the recommendation is for a metal bracket but it's not 100% necessary as long as the thing holds in there nice and strong.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
