  • Replies 51
I think you can get turbo smart gates for like 600ish if you look around?
but then youd need a manifold suited to an external gate.
also, if you turbo is internally gated, im not sure if you can run an external gate, infact, i think no, you cant at all.
Guys.....sooooo sick of ppl gving other (not as knowledgeable) 'posters' sh*t about what they post about. Not everybody knows everything! is it so hard to tell the guy that he is getting ripped off and possibly steer him in the right direction rather than being smart as*es and laughin, wtf? Yeh sure he could go looking in the FI sections but who has time to search...besides, it was a simple question anyway!
1650 for a supplied and fitted wastegate....for starters, look who quoted that price...rigoli bros (LOL) - i wouldnt go within 100 miles of those dodgy c**ts and secondly, for another 1650 you could almost get a wicked GT3040 setup with the works
NISSAN SKYLINE R33 GTS-T 600HP TURBO KIT
INCLUDES:
GT 3040 600 HP BALL BEARING TURBOCHARGER
(.70 COMP & .82 EXH HOUSING), TIAL SPORTS 38MM EXTERNAL WASTEGATE, EXHAUST FLANGE, MODIFIED STANDARD MANIFOLD TO SUIT & BRAIDED OIL AND WATER LINES. about 4g's
I'd be going down that path if i were you...stuff just gettin a wastegate...go all out son and save your pennys haha.
regards, Lukas...
oh yeh and the reason WHY i called rigoli... was just to get a quote... so i know what im looking at... im gna keep looking around.. if its gna cost me more than $700-$800 to get what i want... il just save up n go for a turbo upgrade like u said.. but thanks for the info lukas.. :P
Gotta love the last 3 words in his post
INCLUDES:
Its about $2350 more than the $1650 you've already been quoted
lol..They dont see the difference.
Im like you...maybe not...but diddnt he want to spend less money...I think this is a dreamers thread..ahhhh!!
well.. i got a twin plate clutch, ecu, tein coilovers, im looking for some injectors atm.. and for diff well we will have to see if it wil handle such power... but either way.. its a long time b4 i start thinking of a turbvo upgrade... right now i want my ext wastegate/screamer pipe if i find one fitted for under $800 :)
Yeh nice one NISMOID. Your a smart one arnt ya. Ok yeh sure its like $2000 or whatever more that he was quoted but he was quoted for a freakin wastegate install....ive simply suggested that he saves up his money and get the actual parts that a wastegate is meant to support. Rami didnt actually state what his budget was so i am merely giving him some useful info which is more than u could offer. Whether he listens to it is up to him but i hav just gone down a similar path and its definatly worth saving for. Before you critisise other ppl's suggestions why dont you make a useful one yourself.
GOTTA LAUGH AT THE FACT THAT YOU THINK YOUR GODS GIFT TO SKYLINES LOL>
Laugh that one up NISMOID
Regards, Lukas
Yeh i can see the difference very clearly....get ripped off buying something that will do jack for his car or spending and saving his money more wisely and gettin a killer setup...gee i wonder which is the smarter approach?
Rami never actually said he wanted to spend less money...he simply wanted to know whether he was getting ripped off and what he should do...i hav given him my 2 cents.
Dreamers thread? 4g's isnt alot of money for something that is gonna make his car faster...the only "dreamer" in this thread was rigoli bros when they quoted such a rediculous price. They shouldnt need the money, they just gotta go out and steal one of our cars -----> C**TS
Regards, Lukas
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
