Hi all,
I have purchased a Turbotech boost controller, whacked it in... have a query which I posted in the monster thread but I think it would be better off here. Any help would be much appreciated!
Has anyone else had issues with a boost spike to over 12psi even with the screw barely tightened? Could this be caused by the ball bearing not being seated correctly?
Hi mrgilly,
Boost spike with a gated controller such as the Turbotech is unlikely to be caused by the controller in itself. keep in mind that there are many factors relating to the usage of boost and it differs from car to car.
Boost spike most definately will not be cause by a ball bearing not seating nicely.
In fact, if the ball is not seating tightly it will be hard to get high boost levels as it wont hold back the pressure very well. Boost spiking tends to be related to other car components and it is exaggerated differently between different controllers. advice that I have been given is that spike is very often related to modifications done willy nilly without expert computer and dyno assistance in the planning.
Thanks for that.
The only mod on my r34 otherwise is a cat-back exhaust...
Are there any other common causes to this i.e. stock parts needing replacement etc? Is it likely my stock boost gauge is just cactus?
Cheers
Mines been fine, check the spring hasn't caught on the bur some times created by the small drilled relief hole in the side of the boost controller.
I had to remove the bur in order for my boost controller to adjust correctly.
If the ball isn't seated correctly it won't make higher boost levels, it will be lazy and chances are will only hold near stock boost levels.
If the spring is caught on the bur preventing ball travel then this may cause what you are experiencing.
first of all, is the boost spiking to 12psi then dropping back, or just going to 12psi and staying there? these boost controllers don't take much of a turn to change the boost, so if it is staying at 12psi, just unwind it a touch (1/4 turn or so).
i found with mine, when it was fully wound out boost was a bit spikey, then when i wound it in a touch the boost dropped, then as i wind in further the boost rises agin. my mate had the same thing with his turbosmart boost tee.
mine spikes to 10 on rapid acceleration in 2nd/3rd.. than settles to about 8psi.. if I ease the boost in.. it won't spike..
I think this is due to a rush of boost as it comes on and the bleed valve can't quite accomodate it quickly enough..
Interesting, it's spiking to just over 12 then dropping slightly but staying high. I may try winding it in slightly to see if this is the problem.
Will try it after work today
Thank you.
are you trying to run 12psi? if you are then just leave it there. i thought you were trying to run lower boost and that was as low as you had got it. it may be other things that are making it spike, such as the bov leaking. what exhaust setup are you running? if you are still running stock dump/front pipe then that could be another cause.
Stock gauge is good for making sure your making boost.. after that.. I wouldn't use it.. how do you know it's making 12PSI.. could be making 10psi not much difference on the gauge.. especially when driving..
Grab a boost gauge.. T it in.. than see how you go.. personally my turbo timer has boost as well.. and gives me a MAX reading which helps alot..
Well, my guess is that 3/4 up to +1bar is 10.5 psi and it's definitely above that :)
Thanks for all the advice, I shall investigate an aftermarket boost gauge. Shame they're a pain in the ass... can't just switch out the stock-o
so does mine but i found that it is nearly pointless to use as it isn't a true indication. it only reads the max that it spikes to. so if on a gear change it spikes up 2psi above what it is actually running at you will think that you are running that boost.
I use 2 x things.. 1 is the max to see what it's spiking too.. and than I use the current real time boost display to see what it's running when your @ full boost with load.. e.g. up a hill in 3rd.. used a video camera to record it and review it while I was tuning it in..
Also if you slowly build the boost up rather than quickly slamming the accelerator and having it ramp up - it's less likely to spike and you'll be able to see what your running with a max boost setting
Edited by Links
i started off using both but then just went to using the boost gauge. i was just pointing out that it will only show the spike max for anyone reading this that isn't that knowledgable about this sort of thing so they don't think that their boost gause isn't working properly.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
