So my car has been sitting in a workshop for 9 weeks next monday...and has not been started.
Its a S2 R33 GTS-T.
Hoping to pick it up next week, so i was just wondering what issues, if any should i look out for and look to prevent if possible?
I'm expecting the fuel to be shit (3/4 tank :P) so i'll just drive around nice and easy till thats all gone....was also thinking of putting in a bottle of injector cleaner when i pick it up...
New clutch will be in, so i'll be taking it easy for the first few hundred k's anyway...
Any other issues that may arise?
do these engines shit themselves after having not been started? knowing my luck, ill start it, and it'll go bang!
Thanks
Dezz
https://www.sau.com.au/forums/topic/125273-car-not-started-for-9-weeks/
i'd soo laugh if it went bang :P
...jokes dezzy my boy lol, i know what its like for ur engine (engines in my case) to let go on u...y not be on the safe side and drain the petrol and replace it straight away?
i'd also make sure u prime the car for a fair bit before u go to crank her over, that's about all i got to add other than cross ur fingers hehe
Is it advisable to use injector cleaner anyway?
I was considering this lately.
I've always avoided these additives in the past as a rule of thumb. they're usually not very good or useful.
But i've heard ppl on this forum using them, better fuel economy, smoother idel, etc.
opinions ???
also, sorry for hijacking, i have a habit of doing that. but it's ok, coz i dont care :P
thanks for the replies (except the hijack, please start your own thread or search)
I used injector cleaner when the car was first imported, but havent used it since...dont really see the need if you're using good fuel all the time which we do.
the last thing i need is for the engine to go after all this
lol, you told me off for hijacking, then answered my question anyways. excellent.
i dont see why you'd have probs just coz the car has been sitting.
except for maybe a low battery and 'stale' fuel. but nothing serious.
dezz, im pretty sure if the engine did munch itself, ud cry, caus i know i would, if it was just because the fuel was stale.
so do the right thing and change that fuel, hell im sure u can find a use for it somewhere else
It'll be fine mate. Our cars sit on the dock for even longer before we get them.
I can't remmeber how long it was, but I think the buying, shipping, sitting, compliance etc of my car was about 6 months.
Just drive easy. You don't need injector cleaner or octane booster or anything.
i imported my car, and it was no where near 6 months for me...thats why i bothered with this thread
My car was moved from the auction house to the docks, where it sat for 3 weeks...it was started when the guy in japan went to take some photos for me (i have a photo of it at idle) and then again when driven onto the boat.
2 weeks later it was driven off, and then could only have been left turned off for a max of 2-3 weeks
thanks for the reply though. hopefully its all good
My car took 6 months. Also, many cars just sit at the auction holding yard waiting to be sold and stuff for ages. A soarer that we imported sat for 9 months before it was bought.
Basically, it'll be fine. I wouldn't worry about the fuel or anything. E.g. my car, on the dock, it needed a jump start, drove it straight off the dock to hobbs brothers, where I then drove it to compliance. simple.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
