Hey guys, I never wanted to have to post about problems with the car, but tonight, I was driving along, and then something felt like it let go.. The car started making a loud squeeking/grinding/screeching noise when ever It moved back and forth in gear..
So i got home, started looking under/inside all around the car, brakes etc etc.. and then I went to fiddle with the gear stick and the dam thing went into 3 and 4 without me even having to step on the clutch..
So I'm pretty sure that's where the problem is.. but why would my clutch/gearbox make that sort of screeching sound?
Oddly enough, it stopped on the way home.. which was for good or for worse...
I think all of it is under warranty though.. ( bought from a dealership with 12 month warranty ) so we'll have to see..
Any ideas as to what you guys think happened to the car?
https://www.sau.com.au/forums/topic/125281-is-my-gearboxclutch-screwed/
the noise.. no idea. but with the car off, u can still put the car in gear without putting the clutch in, its usually a little bit harder, but the synchros are probly just lined up for 3rd n 4th wen u turned the car off
EDIT: Turns out I'm a real idiot I think.. I never knew you could change gears without the clutch when the car is turned off... ( don't think I ever tried ) So yea, can't change gears when she's on but can when she's off.. sound normal? lol
Edited by ignuz
Can you depress the clutch? If not then thats what gone, either one of the main bearings in there or the pressure plate itself.
Same sort of thing happened to me, one of the springs had fallen between the plates and caused some damage all the way back to the bearing. Do not try and drive it if this is what happened...
It lets me despress it.. Read my edit above as to my gearbox thing that I thought was happening.
EDIT: Makes no difference probably, but tonight I filled up on Optimax after previously running Ultimate.
Edited by ignuz
squeaking and grinding could be the clutch slave cylinder? It's the piston bolted to the side of the box. Have a look to see if it's wearing on the fork too much or something.
Otherwise, squeaking commonly comes from the clutch pedal/spring from under the dash.... it's hard to tell exactly where you are saying the noise came from.
Does it still do it? Or has it stopped?
Is the clutch working properly? or not at all?? Does it grind as if it's trying to change gears without the clutch depressed??
The clutch appears to be working fine, no grinding, the squealing noise has stopped...
I doubt it was the gearbox, I think it's something to do with the rear driveline of the car, maybe the back left suspension... feels a little weaker in that corner when driving the car around... Im yet to push it again.. I don't want the whole rear to fall off lol
does your gearbox have inspection covers??...
check all your rotors for deep abrasions if a stone HAS somehow lodged in.
do a service on your car, drain engine oil and gearbox oil and diff oil and check for any large lumps of metal,
remove rims and visually inspect your suspension.
hope this helps.
hope this helps.
Well I'll get someone to take a look at it soon while also getting an oil change, thanks for the help guys.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
