skylinesome Posted July 9, 2006 Share Posted July 9, 2006 Hey guys just put in a new pioneer head unit and i dont want the antenna going up all the time when playing a cd. Is there away you can hook it up to your head unit so it dosnt do this or do you just have to disconect the antenna wire from the head unit so it dosnt go up at all. Link to comment https://www.sau.com.au/forums/topic/125372-antenna/ Share on other sites More sharing options...
Chris Rogers Posted July 9, 2006 Share Posted July 9, 2006 put a switch on it. Link to comment https://www.sau.com.au/forums/topic/125372-antenna/#findComment-2315692 Share on other sites More sharing options...
RANDY Posted July 9, 2006 Share Posted July 9, 2006 LOL! My car arrived with a Sanyo CD player, and the same thing happened. I got my new head unit, wired it all up (correctly) and now it only goes up with radio. Might want to check your wiring, the bodgy person who put the first one in ran the antenna wire to the head unit's remote wire. (used for switchin on amps) That made it go up each time. Link to comment https://www.sau.com.au/forums/topic/125372-antenna/#findComment-2316127 Share on other sites More sharing options...
Plat Posted July 9, 2006 Share Posted July 9, 2006 your gonna have to loop the remote wire out to a switch, as far as i know most pioneer headunits dont have a seperate wire for ariel, my 6800 just has a remote wire Link to comment https://www.sau.com.au/forums/topic/125372-antenna/#findComment-2316419 Share on other sites More sharing options...
RANDY Posted July 9, 2006 Share Posted July 9, 2006 (edited) omg lol wtf! Ditch that head unit! What kind of HU doesn't have a power antenna wire?? My first ever headunit was a Kenwood, bought for $40 from Cash Converters... about 6 years ago, and it was already a few years old at the time. IT had a power antenna wire! Edited July 9, 2006 by RANDY Link to comment https://www.sau.com.au/forums/topic/125372-antenna/#findComment-2316725 Share on other sites More sharing options...
skylinesome Posted July 9, 2006 Author Share Posted July 9, 2006 My head unit is a pioneer and it has a power antenna wire but the antenna stays up when you turn the head unit on. im thinking of just unplugin the antenna power wire so it stays down all the time. Link to comment https://www.sau.com.au/forums/topic/125372-antenna/#findComment-2316761 Share on other sites More sharing options...
RANDY Posted July 10, 2006 Share Posted July 10, 2006 Did you install it yourself? Have you checked the wiring? Make sure your remote wire is not touching anything (unless you run an amp, in which case it should only be connected to the amp remote wire) I'm pretty sure that Pioneer wouldn't design it like that, and i'm very sure that R33's antenna's don't do this on their own. Link to comment https://www.sau.com.au/forums/topic/125372-antenna/#findComment-2318700 Share on other sites More sharing options...
skylinesome Posted July 10, 2006 Author Share Posted July 10, 2006 I will re check everything. When you mean make sure the remote wire isnt touching anything, do u mean that is should be connected to the remote power antenna wire coming out of the head unit? or should i wire it so the wire for the antenna coming out of the car goes to nothing. Did you install it yourself? Have you checked the wiring?Make sure your remote wire is not touching anything (unless you run an amp, in which case it should only be connected to the amp remote wire) I'm pretty sure that Pioneer wouldn't design it like that, and i'm very sure that R33's antenna's don't do this on their own. Link to comment https://www.sau.com.au/forums/topic/125372-antenna/#findComment-2319571 Share on other sites More sharing options...
RANDY Posted July 11, 2006 Share Posted July 11, 2006 Umm.. the remote wire FROM the HU: If you have an amp, make sure it's connected to the amp's remote wire. If you have no amp, that wire should be taped up and tidied so that it doesn't short on metal or anything. It should NOT be connected to your antenna wire (factory loom side). The HU should have a "p.cont" or "antenna" or something wire... this is the one for the antenna. I'd be shocked if a modern HU DOESN'T have an antenna control wire. I might have made that unclear... HU "Remote" wire -> nothing HU "Power Antenna" wire -> antenna power wire in the factory harness Link to comment https://www.sau.com.au/forums/topic/125372-antenna/#findComment-2321359 Share on other sites More sharing options...
skylinesome Posted July 12, 2006 Author Share Posted July 12, 2006 ok so let me get this striaght. The wire that powers the antenna goes to nothing. And then the actual antenna wire just plugs into the head unit as normal. If that is the case i dont see how the antenna will power up at all??? What i have done for the mean time is just wired it to the switch next to the a/c unit. I might leave it like this so i can control the antenna even when i have the radio on. Umm.. the remote wire FROM the HU:If you have an amp, make sure it's connected to the amp's remote wire. If you have no amp, that wire should be taped up and tidied so that it doesn't short on metal or anything. It should NOT be connected to your antenna wire (factory loom side). The HU should have a "p.cont" or "antenna" or something wire... this is the one for the antenna. I'd be shocked if a modern HU DOESN'T have an antenna control wire. I might have made that unclear... HU "Remote" wire -> nothing HU "Power Antenna" wire -> antenna power wire in the factory harness Link to comment https://www.sau.com.au/forums/topic/125372-antenna/#findComment-2322766 Share on other sites More sharing options...
skylinesome Posted July 12, 2006 Author Share Posted July 12, 2006 ok after reading it agian it makes sense. My bad But that is how i have wired it but the antenna still comes up when playing a cd. ok so let me get this striaght. The wire that powers the antenna goes to nothing.And then the actual antenna wire just plugs into the head unit as normal. If that is the case i dont see how the antenna will power up at all??? What i have done for the mean time is just wired it to the switch next to the a/c unit. I might leave it like this so i can control the antenna even when i have the radio on. Link to comment https://www.sau.com.au/forums/topic/125372-antenna/#findComment-2322779 Share on other sites More sharing options...
RANDY Posted July 12, 2006 Share Posted July 12, 2006 Ah ok.. and yeah, the wire that you referred to is not actually an antenna power wire, it's the remote wire for an amp. The antenna itself is powered via wiring in the boot. Very odd that this would happen. 100% sure that you haven't got the remote and the antenna wire switched around? Link to comment https://www.sau.com.au/forums/topic/125372-antenna/#findComment-2323986 Share on other sites More sharing options...
