tan18d, feel free to do so via PM. As far as I understand, you cannot bad mouth companies here as it is somewhat of a public pladce and SAU could be sued for defamation...
that's what I thought anyway but I'm not an admin......
  • Replies 53
What Ronin said is right - We do this to protect SAU from any possible recourse.
We wouldn't want SAU taken down for something that can be avoided.
People have seen your story and are welcome to use PM or private e-mail if they really want to know more.
Thanks for understanding.
  • 3 weeks later...
Thought I would let you know that I had my Apexi tuned at Ric Shaws yesterday.
I had the last tune(s) at a different shop (had to take it back) after my engine rebuild and I could feel that it wasn't right, Ric's dyno read that it was making 152rwkw. After Ric had finished it made 185rwkw. This is a result I can feel, in perspective - a 20% power increase, plus the car is generally better behaved.
He did keep the car overnight, which pissed me off 'cos I had to catch a train home (2.75hrs vs 1.25hrs in the car) but he needed the car to get it right.
Total cost $330 = less than $10 per kilowatt.
ohshi3t, the problem with mines ECU is that the eprom is glued too securely to the circuit board. Open it up and take a look you see a secondarycircuitboArd on top of the factory one. And if you unscrew it, you'll notice the there is a shitload of glue on the ROM,making impossible to take out and therefore no one cept mines can tune the mines ecu. If you decide not to go aftermarket, i think you can desoilder the secondary circuit board and install tuned rom yourself.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
