hi guys
can any one help me with names or codes 4 a dr30 thats red and back.
i am tempted just to paint it beacon red (like the ausie r31) but i would prefer not to respray the whole car.
if any of you know of any reds that sute the r30 please let me know.
thanks
Blake
https://www.sau.com.au/forums/topic/125508-dr30-paint-help/
hi guys
thanks
Blake
Are you sure that's it's black & not dark metallic blue?
My RS-X is red & blue, which are both Nissan colours that my paint shop got from their books, apart from that the paint code is written on the build plate.
https://www.sau.com.au/forums/topic/125508-dr30-paint-help/#findComment-2327381
cheers 4 the reply,
my prob is that my car was not red from the factory i think it was white.
is it possible 4 one of the red and black/blue? dr30's to give me the numbers from the plate?
thanks
Blake
https://www.sau.com.au/forums/topic/125508-dr30-paint-help/#findComment-2330571
cheers 4 the reply,
thanks
Blake
The 'Colour Trim' code of my car is '276 Z'
https://www.sau.com.au/forums/topic/125508-dr30-paint-help/#findComment-2331232
I dunno about blue??? All the pics of RS turbos I've seen look solid black (ie not metallic) to me under the bump-strip trim.
I used Beacon Red and Jet Black on my HR. Let's face it, its not an original RS turbo, it really doesn't matter if you don't have the exact colour. If you are doing a full colour change, it matters even less. I could get the paint code I used if you want - there are about 4 or 5 different Datsun Beacon Reds.
and FWIW, I don't think the paint codes on these old Jap Imports mean much according to the Aus specs Nissans paint codes in the books. According to the paint code off my HR30, its white. And trust me, I've painted enough cars to know this one was never anything but red.
Edited by hrd-hr30
https://www.sau.com.au/forums/topic/125508-dr30-paint-help/#findComment-2337033
so the r30 in the photo is beacon red?
i have come to the conclusion that its going to be beacon...LOL
i have a s110 gazelle in beacon ppg 2 pack and it looks good i was just worried what it would look like with black 2 tone.
https://www.sau.com.au/forums/topic/125508-dr30-paint-help/#findComment-2366065
I can back up this therory... My Iron Mask coupe with original stickers etc was a crazy arsed dark mettalic blue.. Could only really tell it from black in bright sunlight.
https://www.sau.com.au/forums/topic/125508-dr30-paint-help/#findComment-2389298
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
