Well.. as my luck never seems to get better it appears that the motor in my sunroof is giving up..
It will go up and down, however it doesn't have enough grunt to move it back and forth and I have to physically assist it..
I've rung nissan - $720 for a new motor..
What are peoples thoughts, is it worth taking to a sunroof place and asking them to have a look at it? Or what else could it be? maybe it needs a good bit of grease..
I'm getting frustrated with this car!!..
How easy would it be to get a second hand motor?
Any help would be great.. cheers
Links
https://www.sau.com.au/forums/topic/125526-my-sunroof-is-dying/
Yo man,
Before doing anything else check where it would be receiving the most restriction and spray it with silicone lube. It comes in a can and is greasy-ish.
My power windows were like that when I got them, sprayed the rubbers that sit at the top of the doors and they went like new. Only did it once in the car and didn't have to re-apply.
Worth a shot - LUBE RUBBER!!
Cheers CC.. i'm going to go see my mechanic this arvo and i'll probably have a look at it later this week when changing the gearbox + engine oil..
The motor isn't completely dead, so there is a chance that something has just dried out and that the slidy rails are getting stuck.. it deteriorated quite quickly.. moved well.. than not as much.. than not really at all..
Cheers for the suggestion i'll try it out..
Ok - turns out the motor is still ok.. i've just been down mucking around with it for 30 minutes..
It appears that one of the feet that it slides on has probably lost a screw and because of that isn't a) moving straight.. and b) not working..
SOOOO.. the next question is.. how the hell do I get to the little feet thing.. i've goto take out the glass I think...
Any ideas people?
little feet thing? you mean the bit that the glass roof part bolts on to the rails?
there are two little plastic screws on the inside.. just unscrew them and then it's two bolts either side. then go from there... you'll see the light from there!
when i replaced my sunroof, I found so much gunk in the rails and I cleaned it all out with rags and a cotton bud to get in to the smaller spaces and re-lubed it using a combo of silicon spray and bearing grease.
I had also found htat part of the little feet thing was actually broken into the rail jamming things up.... well i actually broke it and then felt all tough for being able to fix it again :D lol
Sounds like it could be the same thing..
It has 3 x bolts holding the glass to the feet which are attached to the rails..
I could get to 5/6 nuts.. but couldn't get to the 6th one.. I also checked out the S15 service manual which has a similar design sunroof and gives step by step guide on how to adjust and remove..
Sooo tomorrow morning i'm going to mechanics to get oil change + see if I can fix the sunroof.. I think i've got a similar issue to yours - in that a screw or one of the feet had broken..
Did you end up fixing it yourself - or did you need parts?
Atelast if I can get it back to sitting level & not letting water in I can wait till parts arrive - otherwise it's no rainy driving for me..
Cheers Liz for the info - I think i'll clean it up as well @ the same time..
Ahh the price you pay for getting sunburnt..
My one needs to be assisted also. I hate it.
Last winter water used to come into my car. Through the sun roof, pulled the back seats out the trim out and removed the sunroof. This is very difficult 2 person job as the sunroof weighs a tone and its very hard to get out the door. Found out water is actually meant to come into the sunroof then drain out thru hoses in the a and c pillars. Mine was clogged and had to clean them, hence water leaking.
After I reinstalled it, I found out that I have done somthing wrong and cant control reverse wit the button anymore. But the Up down button controls both up down in and out. Wierd but it does. And yer I still need to assist. One day I'll open and do it all again.
Would like to know what your problem is if you over come it. Good luck!
yeah i fixed it myself links....
if you need sunroof parts speak with Powerplay Imports as I know they have a 33 sunroof there... it was out of a s2 and all in tact (except for the glass bit which i took lol)
lastemptation- it may be as simple as a small part stuck in the rails.. just takes a little patience to work it outl.
  • 2 months later...
liz helped me out, my sunn roof, gets stuck sometime so it's a bit hard to open, but i didn't want to pull all the rails out, greased mine up a bit, and seams better, but basically it doesn't always close streight, well use to.
I had to shimm up my glass with some home made shimms, out of LINO, cos it's soft and squishy, and used them under teh sunroof tabs to bring the roof up, but to get it allighned properly, you need to undo all the 6 bolts, when the roof is closed and then fiddel with it to get exact allignment.
I have studied this diagram and looked at the sunroof but I cant figure how to get to the bolts.
Do I need to remove the trim?
How?
Could you circle the bolts in the Diagram for me?
I sort of figured it was the shims but couldn't figure out how to get to them to pack them up.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
