I've seen idiots attempt to fix sidewalls, and well lets just say I still call them idiots.
I think operating a power tool outside in the pooring rain would be a little bit safer than driving on a tyre that has been knifed and fixed.
Still happens, the "Metal" in tyres is really weak, and it is mainly the Nylon and Rubber that holds it in shape. So it is easy to cut. and here in Adelaide, you get idiots that will stab tyres with needles, and then you dont know that it is stuffed till you find the little hole in the side.
depends how big, if its small take it to a tyre shop and they can get it repaired properly.
tyre is sent away and a vulcanized patch is used.
weve done heaps at my work, take it to a tyre shop and ask em
chances arent too good if it got stabbed with a knife though
Edited by salad
theres no metal in the side of a tyre, just nylon cord and rubber, get an old tyre and stab it.
you will be suprised how easy it is, no i havent done this to other peoples cars i have more respect than that. it was done to shitters that had been dumped in the bush near where i live
I dont know any state where it is legal to get a hole in the side of a tyre fixed. spesh on a low profile tyre, the size of a "Gator Patch" that most places use to attempt a repair like that is about 2 inches wide by 4 inches long, and is too thick to use on a sidewall cos it limits the flex of the tyre.
Mate I would just save to get a new tyre. You would only be wating your time if you ran around trying to get someone to fix it, and even then, i wouldnt wanna put it on my car after it was done.
i work at a tyre shop, we send heaps away to factories to get repaired properly, we dont do it at the work shop. dunno the entire process but it comes back with a small "patch" but is different to your normal patch. it is vulcanised into the sidewall properly, unlike normal puncture repairs
but yeah, knife through it probly means its rooted
i'll keep that in mind next time I change tyres.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
