I recently took my turbo off an got my oil and water lines lines cleaned, when I put my turbo back on ( a spare 1 i had which i needed to get oil to the core ) I warmed up the car and oil got through the turbo all fine but then smoke was comin from near the turbo somewhere so i turned the car off ( i thought it was just oil burning from where some spilled when i filled the core up. But on sunday I went for a short drive i came back opened up my hood and smoke wascoming from near the turbo again (burnt oil smoke can smell it) and oil was everywhere in the engine its gone through my atmo bov sprayed on the firewall and all over my inlet pipe and coilpack cover.
Is this maybe that I have filed the core to much and it just keeps puchin to much oil through the turbo and its comin out everywhere or maybe something else? The car hasnt lost any oil pressure on the guage or heated up anymore, or lost any power. What do you guys reckon?
Nick
https://www.sau.com.au/forums/topic/125604-oil-everywhere/
The core will drain itself so thats not the problem. If the oil in the core was backing up you'd be blowing blue smoke and probably have oil through all your pipework rather than all over the engine bay.
Have you made any other changes while you were there?
Banjo on the oil feed not being done up tight is the most likely cause, especially as it has sprayed everywhere. Have you used new washers?
https://www.sau.com.au/forums/topic/125604-oil-everywhere/#findComment-2319660
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
