If it was me I would buy the GTR but not for cops or for legality. Its just a better car. That said a lot of people have said that a nicely modded gtst is more fun than a gtr as it is a bit more 'on edge' being rwd. Having driven a number of gtsts and GTR's I would say that a GTR has much less useable power on the street. Stab the throttle at 3000rpm and the gtst will go. Stab it in the gtr and nothing will really happen for a while.
The Gtr is therefore not as quick a car just driving around on the street. You can can use the power legally on a gtst where as with a gtr you are going pretty quick when you are using the power.
Another point is how fast the car 'feels' a 250rwkw skyline feels MUCH MUCH faster than a 250rwkw GTR. I have been in an 11 sec gtr (300rwkw) that felt slower than a 230rwkw 33gtst. I'm not kidding! To me that is important because I would rather go slower and feel the speed that be travelling faster and it feel slower. I don't drive to go fast I drive to enjoy it. Most people would agree.
As far as modifying a skyline is concerned and the legalitys, you can easily modify one these days and get it engineered and never have a problem. Costs $500-700 if you consult them before you start modifying and the entire car is legal.
To answer your question about what I would do if I spent it on the gtst I would do the following: (I have tried to be reasonably conservative)
HKS GTRS- $2500- has useable power with enough grunt to make over 270rwkw
injectors- $900
Fuel pump- $350
Cams- $700
Power fc- $1000
Labour to put the above in and tune- ~$1400
You will now have up to 280rwkw depending on how hard you are prepared to push the motor with very little lag. One guy made 300.
Suspension
Bilstein shocks and whiteline springs- $1200rrp (might be able to get them cheaper through the club)
whiteline handling pack- $700
Fit and wheel alignment- $800
Wheels
17 inch buddy clubs would be my choice- $1650 new
Tyres- $1000 for really good ones
Stereo- $1200 has me satisfied
I have just spent nearly $15k. Some of you will think some of the prices are high while some are low but I have tried to be conservative. I have seen all these products for the above prices or cheaper. Labour depends greatly on where you take it and how good they are.
I personally wouldn't push the standard bottom end past 250rwkw which the GTRS could do but doesn't have to. Tune the car with 1-1.2 bar and it will probably make around that power and last forever even if you do track days. No point spending all that money if your not going to use it.
If you did all this first thing I would recommend would be a skidpan day and track day to start to get a handle on it. The car would be a mid 12 second car probably even faster with a good driver even on street tyres. In a gtst that is really fast. You won't catch yourself getting 'used' to the power too quickly if at all.
My 2c.
  • Replies 42
Posted Images
After putting some thought into this, the skyline is getting a greddy front mount, electronic boost controller and a power fc fitted in three weeks time.
On thursday I am taking one of these puppies for a spin:
Decided to have two toys to play with
Thanks for all the suggestions, will let you know if i maim myself on the r6
Edited by foamer_69
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
