If it's any help at all, the look excatly the same as the ones that are on the new Pathfinders, so you should still be able to get them through Nissan.
Looks like Nissan put the same part on a few cars.
BTW: make sure you run the climate control diags in direct sun light, otherwise it will return as error code saying that the sun sensor is stuffed.
Good luck
J
https://www.sau.com.au/forums/topic/1260-sunload-sensor/#findComment-25272
Good luck
J
- Doh!
I knew i was forgetting something.... sunlight!! hahaaha.
Thanks for the reminder Jay95R33!:( :crazy:
https://www.sau.com.au/forums/topic/1260-sunload-sensor/#findComment-25281
Hehehe! it's a bit of a trap, I bought another Sunlight sender from the wreckers befor I read that about the sunlight. Sure enough I ran the diags again with a torch shining on the sensor and it workes fine. So now I have a spare one cost me $10
https://www.sau.com.au/forums/topic/1260-sunload-sensor/#findComment-25429
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
