If it's any help at all, the look excatly the same as the ones that are on the new Pathfinders, so you should still be able to get them through Nissan.
Looks like Nissan put the same part on a few cars.
BTW: make sure you run the climate control diags in direct sun light, otherwise it will return as error code saying that the sun sensor is stuffed.
Good luck
J
https://www.sau.com.au/forums/topic/1260-sunload-sensor/#findComment-25272
  Quote
Good luck
J
- Doh!
I knew i was forgetting something.... sunlight!! hahaaha.
Thanks for the reminder Jay95R33!:( :crazy:
https://www.sau.com.au/forums/topic/1260-sunload-sensor/#findComment-25281
Hehehe! it's a bit of a trap, I bought another Sunlight sender from the wreckers befor I read that about the sunlight. Sure enough I ran the diags again with a torch shining on the sensor and it workes fine. So now I have a spare one cost me $10
https://www.sau.com.au/forums/topic/1260-sunload-sensor/#findComment-25429
