I can swap a r32 box in about 2 hours thats on my own with the car on stands ive had abit of practice though. Ive done it about 6 times on my own cars.
The easiest way i found to get it back in is to lay under the car with your head under the sump with the gearbox beside you. lift the bell housing onto your chest so you can push it up with your arms then put your knees under the tail shaft end and push the whole box up and in, its easy to wiggle it about to line up in this position . Its a damn good arm workout too.
  • 1 month later...
Whatever you do don’t get a bunch of mates that aren’t mechanical 2 help u it results in serious pain and a quite hefty swelling when it falls of the jack onto your arm
So I know for next time is there an easy way to get the box off the jack afterwards
  • 4 weeks later...
best way to get it back in is with 2 people:-
Lay the box in about the right spot on the ground.
Get a small rope
Put the rope around the end of the gearbox. Get the helper to get in the car and pull the rope up. This will then lift the rear of the box up. You can then lift the box by the bell housing, and slide it right in. (might have to issue a few height adjustment commands to the helper 1st;)
to get the top bolt in and out easier use a really long extension a swivel joint and a rattle gun. just run the extension up along the top of the gearbox in the tunnel. You can try jacking the front of the engine a very small amount to lower the bolt a bit. DO THIS WITH CARE!!!! Otherwise you'll bend stuff, squash the stuff behind the engine bent various thing in the engine bay etc.
i changed my clutch, and put in thje OS GIKEN crossmission gearset when i had the engien pulled out, so i pulled the GB out to. DAMN, i dont want to do that ever again. at the job i have acces to a 2pole hoist, but at the time i was going to put the engine in we had a 12cyl, 11.3l haulpack engine hoisted on it, because the chain hoist couldnt lift the engine. so we did the job on the floor with 4 jack stands, that is putting the box in, and the engine. and i am not the smallest person i am 6ft 7in. the GTR box is fckin heavy, lifting with 2 persons we were able to put in in position, bolting it on was easy, use airtools :/
Another vote for the really long extention bar for those top two bolts. I actually used Duncans wobly ended extension bars to take it out then my long extension to put it back in. If you have the right angle your ratchet is about where the cat goes in a straight line.
The other thing that is handy is to get your chinese/australian mate to put the socket on the bolt for you with his little hands. :) (Thanks Ed)
Takes me about 500 hours to do anything.
The only thing I can really add to this thread is why are you undoing your tailshaft? And are you marking it when you do to make sure you put it back together the way it was before?
I just undid the 2 bolts holding the middle section of the tailshaft to the body then bent the 3 uni joints until the yoke part came out of the box. Easy.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
