Was the road wet at the time? Sounds like there may have been some oil on the road, which tends to make things a little hairy when it first rains in a while.
ps. If you are on southside, go and see Accurate Suspensions at Timms Ct, Woodridge. I went there recently and was more than happy with the pricing.
https://www.sau.com.au/forums/topic/126165-pls-close/#findComment-2330559
Southside as in springwood. Thats where he is as in Accurate Suspension.
My guess tho is if wheels are 45* out of wack, a wheel alinement wont be much help.
$175 for a tow but. Dude get RACQ today. Go fill out the form and get it. You should be a free to go member so it wont cost you anything. Even if it does, pay the money. We got a tow back from the coast and it was less than that.
https://www.sau.com.au/forums/topic/126165-pls-close/#findComment-2330607
in this case RACQ wouldn't have helped him much...
they would have seen that the problem was due to an accident and anal raped him even more... (this is because their roadside assistance doesn't cover accidents)
i.e. when my hicas lock bar snapped, they claimed it was due to an accident (it wasn't) and wanted to charge me $350 to tow the car 5km home, because that is their "accident" callout rate
https://www.sau.com.au/forums/topic/126165-pls-close/#findComment-2330868
From recent experience, check your lower control arm on the rear, as this is what took the main brunt of my little incident with Mr Gutter
But yes, take it to Accurate Suspension as stated above, they'll sort it out for u
https://www.sau.com.au/forums/topic/126165-pls-close/#findComment-2331692
Yeah i was beeing my cool and lets just say i ended up spining the car 180 and sliding sideways into the gutter, totaly fu&!@# the front wheel it was bent in, my insurance took care of it but the parts and all came to $3,500 because i asked the guy, that was just the parts without the labour, most had to come from japan, i also snaped one of the control arms, and i called racq for towing, cost me $230 for about 2.2km prrrrrrffff go the system lol. And pretty much all the parts had to be imported, best advice i can give u is ring up a couple of places first, just go to www.yellowpages.com.au and have a search and give some people a call, some of them might even be willing to come to you and see the car so you dont have to pay for towing again. And because u have a 33 you should be able to find most parts that you need at the wreckers youd be suprised how many 33's can be found at the wreckers, i know because i wanted to find an ash tray for my 34 and they all just kept say that they have 33 3's. But first find out whats damaged, that would be the best place to start.
Good luck man
https://www.sau.com.au/forums/topic/126165-pls-close/#findComment-2332170
All your left rear suspension is f**ked (upper, lower control arms, toe link, HICAS, possibly the upright) it will have to be replaced, the front is probably the same. The rear subframe is probably bent, The whole thing will need to be replaced, The calliper should be ok and the disk may be ok of your lucky. Your rims will be rooted, if your very lucky they may be repaired but looks unlikely.
This will be a very expensive repair job if done by a workshop - $3k - $5k depending on how much is rooted. If you do it all yourself maybe $2k.
If your were not doing something stupid at the time, you could have hade something in the suspension fail that caused you to loose control, you'll probaly not find the original fault with all that damage.
Good luck dude.
Edited by JCMarshall_Law
https://www.sau.com.au/forums/topic/126165-pls-close/#findComment-2333415
i also like to know what are the stuffs i had damaged.. so far, i guess the brake pad and brake disc need to be machined.. not sure if suspension need to be changed..
here a few pics i got..
still thinking whether to tow to beaurepairs or T jones or to a performance car shop to repair..
any more ideas? btw, alex34, what is a wreckers?
thanks all
A wrecker is a place where they have many smashed cars, some not even smashed and you go there and get the parts u need for very very cheap. There are many of them around brisbane.
https://www.sau.com.au/forums/topic/126165-pls-close/#findComment-2335786
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
