Anyone got any idea what might have cause these failures? The gudeon pins have snapped in two. The same thing happened in two different engines. Both CA18DETs (similar to RB but 4 pot rather than 6), both using Wiseco pistons, both failed in only 100kms.
Its a strange one as I know of lots of people using Wisecos in CAs with no problems and yet this one guy has two identical failures. Any idea what he is doing wrong?
https://www.sau.com.au/forums/topic/126195-strange-pistongudgeon-pin-failure/
piston is not fauling on crankshaft counterweight is it, or crankshaft have excessive endfloat? unless pin is grabbing little end and piston, lubrication problem. never seen anything like it, thats big.
Those are the only pics I have Im afraid. Its a guy in another country thats having probs, I havent been involved with the build myself. The pistons are nothing out of the ordinary, as I say, they have been used with great sucess in a large number of engines to date so I cant see why they would suddenly foul on the crank. I can see maybe one set of pistons being mispacked by Wiseco but two, and both sets going to the same guy? Nah, too much of a coincidence.
Maybe the piston to bore clearance isnt correct and the pistons nipped up when the engines got hot but to snap the gudgeon pics? Ive seen the effects of hydraulic locking and even then it was the rods that bent, not the gudgeon pins snapping.
Very wierd.
Edited by bren
I've seen it before in a V10 Viper and it was a detonation issue. It broke 2 gudegeons and had 4 more cracked ones.
That was a brand new engine with Wiseco's. It was rebuilt and retuned (the right way!) and it's never had anothe problem since, even with the same pistons.
I tend to think that the gudgeon pin tried to sieze in the small end bush . You can see how the bush has tried to screw itself out of the rod and no doubt up against the inside of the pistons gudgeon pin boss . Since both pins are sheared in the middle it seems logical that half the pin was trying to stop the piston articulating with the rod and was the weakest link . Luckily the other half must have kept the small end located in the piston otherwise the rods and pistons would now be schrapnell on the road . I would be measuring up the broken and surviving pins to see if the tolerances were adequate .
I would also check to see if the propper lubrication was available to all four rods/pins/pistons .
Cheers .
Edited by discopotato03
ok. the only thing that causes a gudion pin failer is either a clerance issue or fauly materials. (dodgy gudion pin)
the fact that it shered could be due to the fact that its been hammering away at its self. elongating the piston pin bore and/or hammering the bush in the conrod.
to a point where it has hammerd it so hard that its fractured the gudion pin.
or.. partaly siezing in the pin boss or little end. ie.. one side getting galled andthe othere side being ok.
so basicly the cause is to little or two much clearance inbetween the piston and the gudion pin or two much clearance between the gudion pin and smallend bushing :D
ie.. poor engine assembly.
ps... if anyone for a minute thinks that detonation has caused this please slap yoursefl ;)
I'm with you on this one, detonation isn't going to do this. I would still like to see the big ends as they will probably show more of the story. If the little end is hammer the big end certainly is going to be showing signs of abuse as well.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
