Can anyone recommend a cheap place to get guards rolled?? I just put new tyres on my car and got a wheel align, it now scrubs like crazy, i didn't go up a size, had 265/35 falkens and now have dodgy 265/35 nexxens... Its rubbing on the inner half of the guard lip, the thing is i think i could solve the problem myself with the trusty angle grinder, is this a good idea? (like i'm only cutting the lip of the guard not the visible part of the guard itself).. although i imagine that lip must add quite a bit of strength to the panel.
https://www.sau.com.au/forums/topic/126210-guard-rolling/
Dont cut it youself, the angle grinder could possibly leave some sharp edges.
Hit a hole when turning and it'll slice through that tyre.
https://www.sau.com.au/forums/topic/126210-guard-rolling/#findComment-2331167
If you split the loot with me 50/50 ill roll the guards for you while you do the job... :)
Nah any good wheel shop will do it for you. Most will heat your panels slightlly to stop cracking...
I suggest Superior tyre or Jaxx at Apsley whcih are side by side also...
https://www.sau.com.au/forums/topic/126210-guard-rolling/#findComment-2331348
hmm thanks guys.
Good point about the grinder option, i'll rule that out, only other idea is if i could figure out a way of 'pinching' the lip so it sits higher up, without buckling the guard.
Guess its better to get a proper rolling, col i suggest an oceans 11 style heist on the treasury :) or maybe the italian job is better- use 3 r33's and call it the japanese job lol
https://www.sau.com.au/forums/topic/126210-guard-rolling/#findComment-2331398
be careful where you go. my dad got his guards rolled at jax and they did a crap job. they cracked the paint, if you look closely the guards are unevenly rolled & inside the wheel arch its all messy where the metal has been pushed back. When my dad complained about it they didnt care because they had already got his money from the new 19's he just bought.
https://www.sau.com.au/forums/topic/126210-guard-rolling/#findComment-2334933
sell car .... buy GTR or V35 ... flared guards already installed :D
https://www.sau.com.au/forums/topic/126210-guard-rolling/#findComment-2336046
hey, my rear tyres were being cut by the guards before i rolled them (had about 300kg worth of stuff in the boot, and 4 passengers, on stock suspension, so it was sagging a farkload) so i pulled the rear wheels off, bashed the inner lip of the guard up flush on the inside (even flared the guards a tiny bit) and it turned out fine!!!!! wouldn't recommend it on a skyline though :blush:
mind you, this is in the middle of nowhere (Torbanlea, which is halfway between Maryborough and Bundaberg)
https://www.sau.com.au/forums/topic/126210-guard-rolling/#findComment-2338801
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
