  • Replies 103
Originally posted by red900ss
I have no problem with speed cameras outside schools. If it saves one kid then it's worth it. :)
Remember these are little individuals who don't always know or think about what's goping on around them.
Typical thought process: "there goes ball, must get ball..."
now speed cameras on multilane roads and freeways and Spit Hill is another matter all together... :D
Dino, this one I think.
Ivan, you know, this was probably directed at primary school children...I'm sure you've seen kids run onto a road without looking...imagine how you'd feel if you ran someone over, whether or not it was your fault.
Well, I'm no fan of speed limits, but in built up areas, with cars parked on either side, it is VERY hard to see someone coming from behind the car.
And it has been proven that speed makes a significant differance to stopping distance. I'd rather drive 20km/h slower and miss the kid
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
