  • Replies 103
Originally posted by red900ss
I have no problem with speed cameras outside schools. If it saves one kid then it's worth it. :)
Remember these are little individuals who don't always know or think about what's goping on around them.
Typical thought process: "there goes ball, must get ball..."
now speed cameras on multilane roads and freeways and Spit Hill is another matter all together... :D
Dino, this one I think.
Ivan, you know, this was probably directed at primary school children...I'm sure you've seen kids run onto a road without looking...imagine how you'd feel if you ran someone over, whether or not it was your fault.
Well, I'm no fan of speed limits, but in built up areas, with cars parked on either side, it is VERY hard to see someone coming from behind the car.
And it has been proven that speed makes a significant differance to stopping distance. I'd rather drive 20km/h slower and miss the kid
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
