  • 5 months later...
Hey
I ended up getting the castrol vmx80 for my gearbox but i never bought any diff oil, i'm about to get some of that redline 75W90 for the diff, the only thing i'm not sure about is do i go for the synthetic oil or the shockproof oil? on there site the 75w90 is listed under synthetic only, not shockproof.
If i do go for shockproof, should i get the superlight - lightweight or Heavy.
thanks
Edited by Hulk1010
https://www.sau.com.au/forums/topic/126666-diff-oil/#findComment-2806116
Redline 75W90 Gear Oil is supposedly good.
I use it in my diff it is very very good , always had problems around roundabouts and tight corners with the inner wheel locking up tried a few oils none were any good , redline fixed my problem
I thought shockproof isn`t an LSD oil only for the gearbox, i use the Blue shockproof in my gearbox its mad too
https://www.sau.com.au/forums/topic/126666-diff-oil/#findComment-2806488
LightWeight ShockProof™
A unique gear oil designed to lubricate racing transmissions and transaxles which see serious loads (not recommended for most syncro-type transmissions). It has excellent low-temperature flow which allows easier shifting when cold. May be used to obtain maximum power transfer in racing differentials which do not see high temperatures. Similar to a 75W140 gear oil, but with the lower internal friction of an SAE 30 motor oil.
Used in two-stroke and four-stroke motocross transmissions (often mixed in equal parts with SuperLight ShockProof™ Gear Oil).
Used in most road-racing differentials with moderate power and dogring racing transaxles.
Taken off the redline website , funny it not recommended for most synro gearboxes works mad in mine
https://www.sau.com.au/forums/topic/126666-diff-oil/#findComment-2807902
Yeah I'd make sure its suited to LSD diff's though..
You don't need "LSD" oil for a standard viscous diff. the viscous LSD unit is sealed from the rest of the diff enclosure and has its own fluid.
If you have a clutch type LSD (ie, you have a GTR, or your diff centre is aftermarket, or you have a skyline with A-LSD) then you need an "LSD" oil with friction modifiers in order for the clutch plates to work properly.
https://www.sau.com.au/forums/topic/126666-diff-oil/#findComment-2808155
I went to repco, autobahn and super cheat auto today and none of them had any redline products that i could see, where can i buy this stuff besides online?
--Nevermind just found some contact locations on there site--
Edited by Hulk1010
https://www.sau.com.au/forums/topic/126666-diff-oil/#findComment-2820264
instead of wasting your money on expensive redline which wont' do anything, because your diff is viscious (separate fluid for the viscous), I would honestly, use a castrol fluid.
Castrol lsx90. Cost ya about $30 for a 4L big bottle. You'll need 1.8L.
Castrol oils are a fairly good place to start from. At least it'll be correct.
Then, see how it feels, if it's good, then fine, it's good. From there, if you have a problem, then go mucking around with different fluids.
I have a mech diff, so I'm using motul oil, just so it changes the properties (won't do much to a viscous).
https://www.sau.com.au/forums/topic/126666-diff-oil/#findComment-2820448
So you only need LSD oil for a mechanical LSD? And viscous LSD has a sealed in amount of its own special fluid you dont ever need to change??
https://www.sau.com.au/forums/topic/126666-diff-oil/#findComment-2821002
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
