There are heaps of importers around, but unless the car is already here then you won't be able to get much, as the RAWS is about to come into effect. That means that only the few dealers which have met the RAWS accreditation will be able to get you a decent car.
See'ya:burnout:
https://www.sau.com.au/forums/topic/12677-importers/#findComment-232768
James,
I've got plenty of Skyline's and Silvias in stock, with more coming, but alas I sell my cars at retail prices. What you get for that is a car that is licenced and fully prepared to the highest standards.
My website is www.c-red.com.au
Regards,
Jash
https://www.sau.com.au/forums/topic/12677-importers/#findComment-233316
Hey James, If you choose to got through a broker to get something imported your going to get something pretty ordinary now that the new laws have been layed out, get something thats already here that you can see, theres plenty around
https://www.sau.com.au/forums/topic/12677-importers/#findComment-233366
James,
I bought my Skyline from Down Under Autos in Jan this year(www.downunderauto.com.au) and they provided a good car and a good deal. They have some Skylines in stock (I've just checked) and they are members of the RAC Dealer Check set up (i.e. all their cars are checked by RAC). If you want any more details, then pm me. I am sure that there are other good dealers around, but I can't comment on those. In the end, it comes down to whoever you feel comfortable with. However, you should get a good enough deal with the specialist dealers who have Skylines in stock, compared to going through an importer. Also as the other guys have said, it is all changing at the moment, not too many people have compliance plates and prices are going to go up as supplies slow down.
Good luck with it.
Cheers.
https://www.sau.com.au/forums/topic/12677-importers/#findComment-233365
on the subject of raws have been talkin to a company that is going through the raws accreditation. As i'm buying the mrs a jsx100 chaser myself and they r complying it in late april they said basically the new system is roughly the same with a few more criterias to obey. With less dodgy dealers and back yard importers bringing in dodgy cars
So really the end buyer is in a win win situation.
And as for those pre buyin checks as a motor mechanic those checks are only good as the person checkin them.
Ive seen a few cars bought at dealers. Suggesting the vehicle is in excellent condition and ive picked the crap out of em.
so fair enough the dealer getting the checks done but also have the thing checked out thoroughly at a registered well known work shop before you hand over the cash. Just a bit of advise
https://www.sau.com.au/forums/topic/12677-importers/#findComment-236039
bought both my cars here and i seem to have had a lot less grief than the people that have imported. Ive heard that with the new laws the cars have to be pretty much stock standard before they are let in too. I guess the advantage of having it already here is theres no waiting and you can have it fully checked out....... but if u get it imported u save a bit of cash but there could be a few griefs and hassles getting it here etc.
Because your dad works where he works - why dont u get one there james? get one of those guys to bring it in?
https://www.sau.com.au/forums/topic/12677-importers/#findComment-236124
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
