Hey. Just wondering, just bought a r33 and not sure what a few thing's under the bonnet are for? This pic and also, i have a T piece that has alot of little hose's attached too it, will get a pic of that later. Car is a 1996 series 2 gts25t.
Any help would be good.
thanks.
Charcoal canister - for emmissions.
on that same note... see how the hoses coming out of this 'charcoal canister' connect to the goldy coloured pipes under the cross over pipe...
why is thair only one connected in our Stagea and the other one blocked off?
is there some sort of performance upgrade related to this?
As far as I know is supposed to eliminate Evaprotive hydrocarbon emissions from the fuel tank by either recirculating them into the intake air (when engine running) or absobing them into the Carbon inside the canister (When engine not running).
Have been told that these charcoal canisters are worthless for this task less than two years after the car has rolled off the production line.... :)
That said, Mr highway patrol and his RTA/EPA mates will happily add you to their defect quota list if they notice that a car originally fitted with one no longer has it fitted. :P
Edited by Redsw20T
sorry to hijack the thread, but does anyone know what the little box at the back corner of the engine bay on the drivers side does? it has a vacuum hose go in and wires come out. the vacuum hose is connected to the hose that goes to the factory gauge in the dash. (car is r33 gts-t)
its hard to search when you don't know what its called, and you can't seach with a picture.
pretty sure it's a MAP sensor
    • So, if the headlights' cutoff behaviour (angles, heights, etc) are not as per 6.2.6.1.1 without automatic levelling, then you have to have to have automatic** levelling. Also, if the headlight does not have the required markings, then neither automatic nor manual adjusters are going to be acceptable. That's because the base headlight itself does not meet the minimum requirement (which is the marking). ** with the option of manual levelling, if the headlight otherwise meets the same requirements as for the automatic case AND can be set to the "base" alignment at the headlight itself. So that's an additional requirement for the manual case. So, provided that the marking is on the headlight and there is a local manual adjustment back to "base" on the headlight, then yes, you could argue that they are code compliant. But if you are missing any single one of these things, then they are not. And unlike certain other standards that I work with, there does not seem to be scope to prepare a "fitness for purpose" report. Well, I guess there actually is. You might engage an automotive engineer to write a report stating that the lights meet the performance requirements of the standard even if they are missing, for example, the markings.
    • Vertical orientation   6.2.6.1.1. The initial downward inclination of the cut off of the dipped-beam to be set in the unladen vehicle state with one person in the driver's seat shall be specified within an accuracy of 0.1 per cent by the manufacturer and indicated in a clearly legible and indelible manner on each vehicle close to either headlamp or the manufacturer's plate by the symbol shown in Annex 7.   The value of this indicated downward inclination shall be defined in accordance with paragraph 6.2.6.1.2.   6.2.6.1.2. Depending on the mounting height in metres (h) of the lower edge of the apparent surface in the direction of the reference axis of the dipped beam headlamp, measured on the unladen vehicles, the vertical inclination of the cut off of the dipped- beam shall, under all the static conditions of Annex 5, remain between the following limits and the initial aiming shall have the following values:   h < 0.8   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   0.8 < h < 1.0   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   Or, at the discretion of the manufacturer,   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The application for the vehicle type approval shall, in this case, contain information as to which of the two alternatives is to be used.   h > 1.0   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The above limits and the initial aiming values are summarized in the diagram below.   For category N3G (off-road) vehicles where the headlamps exceed a height of 1,200 mm, the limits for the vertical inclination of the cut-off shall be between: -1.5 per cent and -3.5 per cent.   The initial aim shall be set between: -2 per cent and -2.5 per cent.
