Hey. Just wondering, just bought a r33 and not sure what a few thing's under the bonnet are for? This pic and also, i have a T piece that has alot of little hose's attached too it, will get a pic of that later. Car is a 1996 series 2 gts25t.
Any help would be good.
thanks.
Charcoal canister - for emmissions.
on that same note... see how the hoses coming out of this 'charcoal canister' connect to the goldy coloured pipes under the cross over pipe...
why is thair only one connected in our Stagea and the other one blocked off?
is there some sort of performance upgrade related to this?
As far as I know is supposed to eliminate Evaprotive hydrocarbon emissions from the fuel tank by either recirculating them into the intake air (when engine running) or absobing them into the Carbon inside the canister (When engine not running).
Have been told that these charcoal canisters are worthless for this task less than two years after the car has rolled off the production line.... :)
That said, Mr highway patrol and his RTA/EPA mates will happily add you to their defect quota list if they notice that a car originally fitted with one no longer has it fitted. :P
Edited by Redsw20T
sorry to hijack the thread, but does anyone know what the little box at the back corner of the engine bay on the drivers side does? it has a vacuum hose go in and wires come out. the vacuum hose is connected to the hose that goes to the factory gauge in the dash. (car is r33 gts-t)
its hard to search when you don't know what its called, and you can't seach with a picture.
pretty sure it's a MAP sensor
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
