hay all, i have a r31 skyline, GXE. i was thinking about putting an alarm system in it, maybe the works, cruise control, central locking and the alarm with an immoboliser, any one know of any good brands, i went to jb hi fi and they recommonded warlock, all the wires are black with tags on them then u take off the tag when u finished installing it so its harded to cut the alarm to steal the car. any help will be great, cheers shaun
https://www.sau.com.au/forums/topic/127481-car-alarms/
im in geelong victoria
https://www.sau.com.au/forums/topic/127481-car-alarms/#findComment-2356015
Yeah i know Chris.
I havnt had another alarm installed elsewhere, just with paying an electricity bill, rego and my 100k service money is abit tight when i have gone back to $300 a week.
when i have some spare cash saved up ill still get you to do it.
https://www.sau.com.au/forums/topic/127481-car-alarms/#findComment-2359657
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
