  • Replies 42
Great pix Joel !
Perfect avatar for BASS, DEZZ :(
Now I can see why Sam was glad when I rang and cancelled my dyno session on Tue cause his truck had stuffed wheel bearings!!
Great pix Joel !
NOTE: I take no credit for the avatar...all I did was link to the one that AGE made :(
