Very construstive advice there Greg, just like the one I just saw in the spotted skyline thread...
Put a resistor in line with the bulb...
Run it in series... About 1 ohm should knock a bit of brightness out of it. Otherwise get a variable pot of lets say 1-5 ohms and then it will be adjustable...
Once again run it in series...
Cost you less than 20 cents for an inline resistor and about $2 for a variable pot...
Cheap as chips...
that's like a beacon out in the middle of the sea.
i dont think u needed to point an arrow to it, i reckon we would have found it anyways.
go the resistor. if it's still too bright, add another resistor, or one of higher value.
Here you go Sean...
Simple wiring diagram for ya... Just need to wiring it in series and your sorted...
Thanks col, only problem is I've mis-placed my manual for it and all the wires are in those wierd american colours, don't know which wire is the one that connected to the head lights. :(
1.) Check the power to the White (illumination) wire. This is your power input to the light and the amount of power will vary depending on how and where you have it hooked up. The lower the power, the dimmer the light and the higher the power, the brighter the light. A common range is from 6 to 14 volts.
2.) If your tach features LED lighting such as Cobalt, C2, or NV models, and you have confirmed power to the White (illumination) wire, please visit the Ask A Question or Contact Us pages to communicate with our Tech Department.
3.) If your tach uses a replaceable incandescent bulb (check your instructions), inspect the filament of the bulb and replace as necessary. Very few of our tachometers use an incandescent bulb that is not consumer replaceable. If you believe you have one of these units, please visit the Ask A Question or Contact Us pages to inquire about having the bulb replaced.
That Might help...
www.autometer.com
    • Install a MAP sensor pre and post throttle. Best data you could have for NA, then play with the bends and/or air box and see how much of inflection is created at WOT on the plot.
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
