  • Replies 91
Posted Images
Batmbl,
Could you squeeeze in one more order please, just saw the post today =(?
R33- GTST stock turbo
if pmnt is an issue i can paypal today or if ur NAB trsfr tonight
Edited by The Milf Guy
Ok sorry to be a hassle again but I'll have to pull out of this one. If another chance comes up I'll take this and the cat, but for the meantime I'll have to wait.
Cheers Batmbl
JieLine
did you used to be HiaTuS.?? if so, yes the payment has cleared.
nsm034,
The pipes will get sent out tomorrow. if you purchased a cat and pipe, then it will get sent out wed or thur because the cats are being made up at the moment.
i will advise people as parts get sent out in this thread, so keep a lookout.
cheers guys
no problem guys, cheers
Parts were sent today to the following people:
Big B R33 (pipe)
JieLine (pipe & cat)
JaiJai (pipe)
17SOK (cat)
jeffworld2 (pipe & cat)
nsm034 (pipe & cat)
cheers
Hi,
What is the dofference between the small and large body CATs other than $90?
Cheers
I'll be in the next group buy seeing I've missed this one. I'll be chasing the ceramic coated pipe for R32
Cheers
Simon
