hey everyone,
i got a new battery put in yesterday, all sweet, except the alarm won't arm now. Have i reset something or do i need to reset something?? Alarm is a Viper, will go into specifics if need be, but i'm hoping it's a simple problem...
cheers,
daniel
i had a toggle switch hidden away for valet mode, should i flick in the opposite way or just flick on/off? i have found the manual, but gotta be up in 3.5hrs (now 2am) so can't be f*cked checking now... i was thinking bout flicking the valet switch about...
well let you guys know what the score is tomorrow, thanks for taking the time to reply, appreciate it :D
copy/paste from other thread...
there is no red light??
i found the manual and there seems to be a toggle switch (which i have) and ANOTHER switch, but a 'push-in' switch, which i don't think i have.
i'm starting to think it's more a valet thing, but all i've got is the toggle switch...
i've have a BLUE LED inside the car, that flashes when armed...
i do have a push button type thing, which seems more like the valet button according to the manual, but the only thing i can think of is a button that is pressed down when the bonnet is closed. But i think that's more to do with tripping the alarm if the bonnet is opened??
i just changed the battery, but had been jump starting the car quite a lot, was still fine then.
I was in africa for a bit of june and pretty much all of July, with the car never turned on in that time.
Jumped the car when i got back to get a new battery, and that's when the alarm packed it in.
Even when i jumped the car after a month, and locked the car when i parked it outside the workshop the alarm was working then. It's definitely the change over to the new alarm that has caused the issues.
I found a thing in the manual referring to code hopping. It says that, and i quote...
"...However, if the remote has been pressed many times out of range of the vehicle, or the battery has been removed, it may fall out of sync with the control unit and fail to operate the system. To re-sync the remote simply press the lock button several times within range of the vehicle. The alarm will automatically re-sync and respond to the transmitters normally."
Now i went out tonight to do this, i pressed the lock button i don't know how many times standing right next to the car. I pressed the lock button quickly like 10 times, pressed it slowly (so it would beep at me after each press) about 5-6 times in a row, held the lock button down, everything... i 99% confident i've ruled out the 'sync' problem, because i definitely pressed the lock button several times within range of the vehicle.
I don't know if it has a backup battery.
In regards to the "programming" I found the part of the manual about it, nothing about PIN and it's just really to program the handheld unit, eg when the alarm goes off, does the remote beep or does it vibrate? Stuff like that, programming turbo timer times, etc... i found nothing about a PIN or any reference to the system not responding.
I did msg my alarm installer but haven't heard anything back from him yet. Will probably call tomorrow, i might msg Danny as well...
any other thoughts ppl's?
it's a Viper 791VX, seems like every man and his dog has one...
chinny
I was half way through that post when it occured to me what alarm it was.
is your push button thing black??
(fire me a PM when you get time and I'll try to help - failing that ring me.)
ok, thanks to Chris's help and some dude from Autobarn, i got the alarm working again.
Key On,
Press valet once, and release
Press and HOLD valet
Press 'lock' on viper remote
relase valet
Key Off
gotta be done within 20 seconds apparently.
I may have un-programmed the remote or something, because remote start doesn't work anymore, but i might just have to assign the button to a channel or something.
So all those owners with the same alarm, and if you get this problem when changing a battery, give the above a shot.
cheers!
daniel
Key On,
relase valet
Key Off
cheers!
daniel
actaully if you read the book again it will tell you how to get around that..
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
